R6300V2 dd wrt LAN IP disappeared
5 posts / 0 new
ice9
ice9's picture
While configuring my R6300V2, I encountered a situation where the IP address of the router is "missing".  A scan of 192.168.0.xxx and 192.168.1.xxx does not yield anything.  I did change the static LAN IP from 192.168.1.1 to 192.168.1.8, and successfully rebooted after that.  But a couple of reboots neither shows up on a scan.
Any ideas?  Does a hard reset affect the IP?  Is it possible to get in through the radios?
ice9
ice9's picture
So I was able to get the
So I was able to get the router back with a 10 second reset.  But I don't know why it is locking up when I change some parameters.
Any general guidance would be appreciated.  I have used this router model for 7 years without problems like this, so I am somewhat at a loss.
devadmin
devadmin's picture
I have seen this sort of
I have seen this sort of issue when the power supply is starting to go bad.
If you have another you can test with you might try that.
ice9
ice9's picture
Interesting.  I have many
Interesting.  I have many power supplies, I will try another tonight.  Thanks.
devadmin
devadmin's picture
Cool,
Cool,
Let us know how it works out.
