Trying to get a hp F4280 printer to work plugged into the router's usb port.
I have Tomato Firmware v1.28.9053 MIPSR2-beta K26 USB Ext.
The printer is just not showing on any computers. I telnet into the router to look if its there and it is. /dev/usb/lp0 it shows on the web interface aswell. I'm not all that great with linux and its been a long time since i used any linux so I dont know what else to do.
I should be able to find the printer on the network under \\lp0 but it says its not there. printer is on....tried resetting router and all that didnt work. Maybe I am missing something ..this firmware is fairly advanced for my level of expertise :)
does anyone have any possible solutions?
problem solved by adding a local printer port pointing to the router ip address while using a pre-installed printer driver. so im rusty....
