Bonehead flash of R6300v1 with ARM branch
5 posts / 0 new
borland502
I can't reflash with tftp, so I assume I screwed the router good.  Will the serial fix outlined here work?
Kong
Yes recovery via serial
Yes recovery via serial console will work.
borland502
Thanks. Your custodianship
Thanks. Your custodianship of this section of the dd-wrt product is the reason I have the R6300v1 and R7000 routers. I appreciate your efforts.
borland502
Serial console flash worked
Serial console flash worked like a charm. Put the R6300 into repeater bridge mode with the new R7000 and things are better than ever. Thanks!
Tsaukpaetra
I seem to be having trouble
I seem to be having trouble fully getting the boot loader to cancel.
Just in case, I found this thread to post on in the dd-wrt forums:
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=921930#921930
