Clients not connecting at high speeds
3 posts / 0 new
ES13Raven
ES13Raven's picture
Running an Asus RT-N16 with Kong 22200M build, and I can't get my wireless clients to connect at high speeds.
Can't seem to get higher rate than 65Mbps as shown in the wireless status tab in DD-WRT and Task Manager on the clients.
Settings changed from default are:
  • NG Mixed
  • Channel 1
  • 20 MHz
  • Ack timing 0
  • WPA2 Personal
  • AES
  • CTS disable
  • Preamble short
  • Shortslot Override short
  • "wl -i eth1 interference 2" on startup
I used inSSIDer to select channel 1, which was the best Link Score for my neighborhood.
SNR varies from 25-35 with the client about 30 feet away in the next room.
How can I improve speeds?
Kong
Kong's picture
Your clients are probably
Your clients are probably single stream wireless devices like mobile phones etc. around 65mbps is ok for those devices under these circumstances.
"wl -i eth1 interference 2" I don't recommend that setting with the latest build unless you have tested, that it works better by doing a long term test.
ES13Raven
ES13Raven's picture
Kong said: Your clients are
Kong said: Your clients are probably single stream wireless devices like mobile phones etc. around 65mbps is ok for those devices under these circumstances. "wl -i eth1 interference 2" I don't recommend that setting with the latest build unless you have tested, that it works better by doing a long term test.
Using an HP ProBook 4540s with an Atheros AR9485 built-in wireless.  22200M looks like it defaults to interference 4 mode.  When mode 4 is enabled, the SNR dips down to about 24.  When mode 2 is enabled, the SNR stays around 35.
If not this build, what build do you reccomend as the best build for the RT-N16?
