dd wrt..... problem with my ntfs hard drive.
2 posts / 0 new
davidmitnick
davidmitnick's picture
DD wrt cant recognize my hard drive its 100gb and its ntfs any ideas what i can do  i dont want to return to my factory soft so pls help.
Disk Info
--- /dev/discs/disc0/disc
Block device, size 93.16 GiB (100030242816 bytes)
DOS/MBR partition map
Partition 1: 39.06 GiB (41943089664 bytes, 81920097 sectors from 63,
bootable)
Type 0x07 (HPFS/NTFS)
Windows NTLDR boot loader
NTFS file system
Volume size 39.06 GiB (41943089152 bytes, 81920096 sectors)
Partition 2: 54.09 GiB (58084024320 bytes, 113445360 sectors from
81920160)
Type 0x0F (Win95 Ext'd (LBA))
Partition 5: 54.09 GiB (58083992064 bytes, 113445297 sectors from
81920160+63)
NTFS file system
Volume size 54.09 GiB (58083991552 bytes, 113445296 sectors)
Status: Not mounted - Unsupported file system or disk not
formated
Kong
Kong's picture
It says it right there:
Not mounted - Unsupported file system or disk not formated
At least with the standard dd-wrt versions you don't have ntfs support, for this the firmware needs to have fuse and ntfs-3g support.
If you format the drive fat32 you should have no problems.
