is it possible to use this http://www.miniinthebox.com/no/pl2303hx-usb-til-rs232-ttl-converter-adap... cable ?
i saw that the collors dont match the one in the tutorial that is on the web site.
plese could any one help ? :)
thanks :D
thanks :D
Yes this adapter should work.
could you tell me what wires on the cable i should use ?
since the colors dosent match with the one in the tutorial :)
