Disable blue led through custom firmware?
3 posts / 0 new
BarMonger
I was wondering if there was any way to disable that annoying blue led (the wifi traffic indicator). It's too bright and it flashes all the time.
Is there any way to dim it/turn it off through custom firmware?
Subhra
As far my knowledge, custom
As far my knowledge, custom firmware does not provide any option to do that from Web UI. It might be possible from console, for that you should have serial console cable to access the console.
Victek
depending of the custom
depending of the custom firmware you are running there are many commands to dim/off LED's .. do a GPIO via telnet to know LED map and let us know.
