Ethernet connectivity issues with v3.0-r28000M
3 posts / 0 new
Marc0_Pol0
I recently upgraded to the v3.0-r28000M kongac (10/24/15) build and since doing so I'm having issues with my NAS not automatically being seen after a router reboot. It's connected directly, and I had no problems with it with the last build (mid 2014). I haven't made any changes on the NAS side, so I'm lead to believe it's an issue with DD-WRT. I've tried different cables in different ports with no luck. I should note that I can't even ping the device, and the router doesn't see it as being connected either.
Any suggesstions? I'd hate to have to flash an older version.
Marc0_Pol0
For anyone running into
For anyone running into similar problems, I was able to find an acceptable (but not ideal) solution. I disabled DHCP on my NAS and had it request the same static IP the router was assigning it, which seems to have resolved it, it's now seen immediately after a router reboot. Unfortunately this method won't work for a client that doesn't have an option to assign an IP internally.
vitfain
Hello ,Are you talkig abouth
Hello ,Are you talkig abouth the dd-wrt.K3_R620_0.chk FW ,from 10-26-15 ? the latest one in FW thread ? Could you tell mhat exactly doesn't work?
