firmware for non wireless router DG814
2 posts / 0 new
hugo91
Hi everybody,
I found in my cave a Netgear DG814 router,
I would like to install an open firware like the dd-wrt.
I already have a WRT54G with a dd-wrt firmware and i like all the fonctionality offered with this firmware.
So i would like to change the original firmware of my DG814 to have more fonctionality (such as vlan, ssh and many other)
Do you kinow if it exist for this router ?
And where could i find that?
Thanks for your help, and sorry for my bad english.Embarassed
achilles
If you look at the following
If you look at the following link :
http://www.dd-wrt.com/wiki/index.php/Supported_Devices
You will find that your device is not supported by DD-WRT so if u want to run DD-WRT on it ... you will need to port DD-WRT for your router ...
