first this is my second router with DD-WRT.
I would install the Firmware from the official dd-wrt website, but it didn't work (maybe the wrong version).
So i take the version from myrouter.de (DD-WRT for NETGEAR WNR3500Lv2 Support Release).
A big problem is that the settings aren't saved when i only click on "Apply Settings". I have a feeling that some changes aren't applied after changing and after software reboot the settings are the old one.
Edit: Wasn't a problem with DD-WRT
Ping from outside don't work. (Setting is correct) -> I can't contact the router from outside, vpn doesn't work too.
The wan IP is a locale one, but i think its a problem with my cabel modem behind it. (but internet workes)
My wish is that a new better version comes the next time or i can use an other one.
Fine would be another design and german language support.
Please excuse my poor english.
Thanks in advance!
Does Tomato work better?
Can i change direkt from DD-WRT to Tomato?
First to apply a settings, it is customary to frist click "save" then "Appply Settings".
You can use Tomato for your WNR3500Lv2, a lot of work have been done in tomato for WNR3500Lv2.
Yes you can directly upgrade from dd-wrt to tomato.
Welche die dd-wrt pflegten sie? Die dd-wrt auf dies website funktioniert - mindestens f?r mich...
You can change from dd-wrt to Tomato but you first have to install dd-wrt, the firmware upgrade program in the stock firmware will not load Tomato directly. But dd-wrt will allow you to flash the router with Tomato.
