Hard reset problem in DD-WRT
3 posts / 0 new
imran
Hi all,
I have build a DD-WRT firmware and flashed my WGR614L with it . With this f/w the board boots OK .... the problem is that with this f/w factory hard reset does no work properly and whenever I do a factory hard reset the boot fails with the following error message :
CFE for WGR614v8 version: 1.3
Build Date: Fri Apr 20 14:04:44 CST 2007
Committing NVRAM...done
Device eth0:  hwaddr 00-1E-2A-07-AC-8A, ipaddr 192.168.1.1, mask 255.255.255.0
Loading .................................
Image chksum: 0x0DE968E6
Calc  chksum: 0x8F3666A7
Loading: . 0 bytes read
Failed.
Could not load flash0.os:: Error
CFE>
Now subsequently if I again flash the router with my DD-WRT f/w using tftpd ... the boot happens properly and all things become OK ....
Problem arises whenever I try to do a reset .... It seems there is some mistake .....
Could anyone plz provide me with some ideas in this regard ....
thnx in advnc ....
achilles
Please look into the thread
Please look into the thread :
http://www.myopenrouter.com/forum/thread/10570/WGR614-chksum-problem/
It is an alignment issue ... hope u will get ur prblm solved using the solution given here ...
imran
thanks achilles ,
thanks achilles ,
Now hard reset is working with the image built by me ... thanks again
