I have a WGR614v7 and i know it has atheros 51xx/2317 chipset 2mb flash rom 8mb vram it is telnet capible of enabling it i wanted to know if the client mode on this router works when i go to that mode the test/check mark simble flickers when its off it doesnt and i heard i have to make a new firmware so if i have people that would like to help me go ahead its going to free to the world. thanks for helping me. or if anyone knows how to make client or bridge mode work please bring it to my attention people at the netgear forums wont give answers at all they wont give support nothing to this and i am no sure why if atheros is so common in routers and computers it should be easy to make a firmware
- Hope this helps.... 2 weeks 9 hours ago
- I have been a diehard nether 2 weeks 6 days ago
- Have you fixed this problem? 4 weeks 19 hours ago
- Sending firmware via tftp did 1 month 1 week ago
- Did you find a way to do 1 month 2 weeks ago
hi geramy ,
I have replied to one of your posts ... plz check it ... also as far as I know this site is dedicated to WGR614L so I m not sure if you can get people working with WGR614v7 at this place .....
And client mode should be supported in your default F/W ...plz check it properly ...
for anyone wondering i have figured it out like i though it works to client bridge witch is set operationmode sta but with no security it works havn't tested yet repeater mode works too even on wpa wpa2 make sure to set superg enable it will disable compresion and that slows it down this will only bridge to 1 computer the rest get ip addresses but no internet i havnt figured out why but i will and update your guys on it
OK ... u need to set the operation mode to sta to get it working as client bridge... Some firmwares (like DD-WRT) provide options of client bridge and repaeter bridge seperately ...
If you are getting client bridge working then it should also work with security ..
Make sure that u use same security parameters at both primary and secondary routers ...
Also if client bridge works then u can configure repeater bridge also ... The only additional thing that u need is to create some virtual AP(s) in your WGR614v7 so that wireless clients could connect to these virtual APs ....
yes your right-ish its only WEP capible currently but when do client mode only one computer will get acsses liek dail up only one computer can use the interent at a time any help on this?
Well, I dont have a WGR614v7 so I can't confirm whether other security mechanisms other than WEP are supported there or not ....
Also in client bridge mode we can connect more that one PCs to our secondary router i.e your WGR614v7 .... The no. of hosts that can be connected is limited only by no. of LAN ports available on your board .....
You can try one thing ..... just make sure that each of the PCs that has been connected to your Wgr614v7 is able to ping it .... I think it is some set up related mistake that you have done in configuring other PCs ....
well um i cant get pings my computers from one that is not getting internet acsses but the one that is is fine so i might by an non wireless router plug the cable into the other router and the router can act as its being pluged into a cable modem lol i have a switch a netgear one just got it but no only one computer will get my first routers gate way and dns server ip's witch is 192.168.0.1 and if i do the others mauly they wont work only the one
OK u can do that set up later but at first try one thing ....
Disconnect the PC which is able to ping the board and access the net from the board and let the other PC which is not able to ping ,remain connected to board ...
See now if you can ping the board or not from that PC .... let me know about the result ...
No it doesnt ping i have bought a switch too so if i might need more ports um would looping the router bridge into the wan port work anyways no i cant ping it but my 1st router see's it
i have tooken my questions to customer support like the first couple days i got it i was tooken to level 2 i think and they wont say anything to me do they have rules to go by or do they just not wanna have people know i told them i know about telnet daimen and i was in ti and i got bridge to work on one computer now i will be wiating i told them to step up and just tell me i already know alot lol they wouldnt lose anything telling me there hoping ill go buy a new one witch if i do im not buying netgear lol
Online technical submission: view case
Case # 8634142
Problem Questions
Cause Questions about setup, Features, Security
Status Open
Notes
1/19/2009 12:47:00 PM
Dear Geramy,
Thank you for choosing NETGEAR, my name is Mohd.Jauhar and I will be your support engineer.
Based on the complexity of this case, it may be appropriate for me to seek additional resources. I recommend escalating your case to the next level for further review and response.
This message is for your information only. There is no additional action needed from you at this time. The next level support engineer will update the case and you will be notified.
A system generated e-mail will be sent to your e-mail address to inform you that we have responded to your inquiry. Please DO NOT REPLY to the e-mail sent to your e-mail address. Instead, If you want to reply to the message above and have additional query, please click "no" when the system ask you "Was your problem resolved with the information provided by the NETGEAR representative above?" When you select YES, your case will be closed and a separate e-mail containing a survey link will be sent to you to measure your customer support experience.
Thanks again for choosing NETGEAR. Have a great day!
Sincerely,
Mohd.Jauhar
Technical Support
NETGEAR, Inc.
***Please be aware that your case will auto-close after 7 days of inactivity***
Did you know that NETGEAR provides support for your home networking devices and PCs? One-stop solution! No need to call multiple vendors* for support. If you would like to learn more about the NETGEAR GearHead services please click on this link
http://kbserver.netgear.com/kb_web_files/gearhead/GearHeadSupport.html.
1/19/2009 7:35:00 PM
Um i know of all the open firmwares but i know you guys must have a firmware that enables the bridge mode anyways i do know about telnet logging in and i know my firmware is unlocked isn''t locked well the chip so all i need is a update with bridge mode or telnet enabled thats all i ask for thats only a change of a line in a code i program myself it would be pretty easy but i dont know how you guys make this stuff so ill leave it to you.
1/22/2009 4:50:00 AM
Good Evening Geramy,
My name is Nathaniel of NETGEAR Level 2 Technical Support.
I understand that you are interested in non-public firmware that enables bridging or client mode in a WGR614v7.
I am sorry, but NETGEAR does not have any public or non-public firmware with those features. However you should take a look at the WGPS606 or WG602v3 as these products support client mode with the latest versions of public firmware
Thank You for choosing NETGEAR,
Nathaniel Williams
Second Level Escalation
NETGEAR, Inc.
**If this was an original email case please DO NOT REPLY to this message, please go to the email portal located at http://my.netgear.com/myNETGEAR/support.asp and reply from there.
NETGEAR Support Contact Information:
Call (Toll Free) 888-NETGEAR or with email support cases, update your case through the portal by visiting our web site at http://my.netgear.com/myNETGEAR/support.asp
For the latest updates to our manuals, drivers, and software, visit our web site at http://www.Netgear-Support.com
1/22/2009 6:00:00 AM
I really dont wanna buy a new one first of all i have figured out that in telnet mode it enables client mode only WEP capible and only one computer gets acsses at a time any suggestions you guys must know you can instantly grab a router and try lol
1/22/2009 10:09:00 PM
We hope that the steps provided above would help resolve the problem/case. Please feel free to contact us again if you will require further assistance.
Sincerely,
Ted B.
NETGEAR Level 2 Support
NETGEAR, Inc.
For the latest updates to our manuals, drivers, and software, visit our web site at http://kbserver.netgear.com/
Did you know that NETGEAR provides support for your home networking devices and PCs? One-stop solution! No need to call multiple vendors* for support. If you would like to learn more about the NETGEAR GearHead services please click here: http://kbserver.netgear.com/kb_web_files/n101650.asp
1/22/2009 10:17:00 PM
Thanks um well first of all i know you guys arnt telling me something i can connect through telnet diamen and enable client mode and it works but only can acsses one computer will soemone stop saying nothing and step uup and tell me what i need to know i can go buy another router that is not from you guys witch i would be pleased to do atleast other customer support will tell you everything i feel like you guys know alot but just wont tell me and if you guys wont help me ill just figure it out eventually and post everywere how to do it and no one will be buying the topdog routers unless they want wpav1 or wpav2 with there bridge but thanks for writing to me about nothing in advanced!
oh i just bought a WGR614v9 anyone wanna help
Can anybody please tell me how to configure brdige-mode for my netgear WGR614 v7.
I understand nothing....
Please help my....it very dificult.
Do I have to install a new firmware on it?
If yes, how?
I have Bharti Broadband installed with Wifi router in one of my room.
The signals are not strong enough to cover another room bit far off.
I have Netgear WGR614, purchased few months back.
Can I use/add this wifi router (WGR614) to add more signals to my other room where signal strength is very low.
Please let me know the procedure and steps needed to do so.
Thanks in advance.
Rakesh Sharad
+91 9810203798
after enabling telnet on WGR614v7 using telnetenable.exe program described here http://www.seattlewireless.net/NetgearWGR614#head-94a70e5e770b17b8df1635...
I was able to login.. I wanted to enable bridge mode to connect its wireless port to another wifi access point, is it possible? dont know yet but saw all these commands wow!
Login: Gearguy
Password: *******
U12H06400> ?
Commands are:
bridge ddns exit ftpc ip
lan nat passwd pot reboot
save show sntp time uptime
version wan web wla
'..' return to previous directory
U12H06400> wla
Atheros Access Point Rev 4.1.4.19-UAPSD1.2
wlan[0,0] -> ?
List of Access Point CLI commands:
add remoteWbr -- Add a remote Wireless Bridge
config wlan -- config wlanX
config virtualap -- config virtual ap
config bss -- config bss
connect bss -- connect to bssX
del acl -- Delete Access Control List
del key -- Delete Encryption key
del remoteWbr -- Delete a remote Wireless Bridge
find bss -- Find BSS
find bssPassive -- Find BSS with passive scans
find channel -- Find Available Channel
find all -- Find All BSS
format -- Format flash filesytem
bootrom -- Update boot rom image
ftp -- Software update via FTP
get 11gonly -- Display 11g Only Allowed
get 11goptimize -- Display 11g Optimization Level
get 11goverlapbss -- Display Overlapping BSS Protection
get abolt --
get acl -- Display Access Control List
get aging -- Display Aging Interval
get antenna -- Display Antenna Diversity
get association -- Display Association Table
get authentication -- Display Authentication Type
get autochannelselect -- Display Auto Channel Select
get beaconinterval -- Display Beacon Interval
get burstSeqThreshold -- Display Max Number of frames in a Burst
get burstTime -- Display Burst Time
get cacheperf -- Display the cache performance counters
get calibration -- Display Noise And Offset Calibration Mode
get cckTrigHigh -- Display Higher Trigger Threshold for CCK
Phy Errors for ANI Control
get cckTrigLow -- Display Lower Trigger Threshold for CCK P
get cckWeakSigThr -- Display ANI Parameter for CCK Weak Signal
Detection Threshold
get channel -- Display Radio Channel
get cipher -- Display Encryption cipher
get config -- Display Current AP Configuration
get countrycode -- Display Country Code
get ctsmode -- Display CTS mode
get ctsrate -- Display CTS rate
get ctstype -- Display CTS type
get domainsuffix -- Display Domain Name Server suffix
get dtim -- Display Data Beacon Rate (DTIM)
get enableANI -- Display Adaptive Noise Immunity Control O
n/Off
get encryption -- Display Encryption Mode
get extendedchanmode -- Display Extended Channel Mode
get firStepLvl -- Display ANI Parameter for FirStepLevel
get fragmentthreshold -- Display Fragment Threshold
get frequency -- Display Radio Frequency (MHz)
get gateway -- Display Gateway IP Address
get groupkeyupdate -- Display Group Key Update Interval (in Sec
onds)
get hardware -- Display Hardware Revisions
get hostipaddr -- Display Host IP Address
get interVF -- Display Inter Vap Forwarding State
get intraVF -- Display Intra Vap Forwarding State
get ipaddr -- Display IP Address
get ipmask -- Display IP Subnet Mask
get jsw -- Display Jumpstart Mode
get jsP2PassPhrase -- Display JS-P2 passphrase
get key -- Display Encryption Key
get keyentrymethod -- Display Encyrption Key Entry Method
get keysource -- Display Source Of Encryption Keys
get login -- Display Login User Name
get minimumrate -- Display Minimum Rate
get nameaddr -- Display IP address of name server
get noiseImmunityLvl -- Display ANI Parameter for Noise Immunity
Level
get ofdmTrigHigh -- Display Higher Trigger Threshold for OFDM
get ofdmTrigLow -- Display Lower Trigger Threshold for OFDM
get ofdmWeakSigDet -- Display ANI Parameter for OFDM Weak Signa
l Detection
get operationMode -- Display Operation Mode
get pktLogEnable -- Display Packet Logging Mode
get power -- Display Transmit Power Setting
get pvid -- Display the VLAN Tag
get radiusname -- Display RADIUS server name or IP address
get radiusport -- Display RADIUS port number
get rate -- Display Data Rate
get reg -- Display the register contents at the give
n offset
get remoteAp -- Display Remote Ap's Mac Address
get reset -- Display # of resets
get remoteWbr -- Display configured Remote Wireless bridge
s
get hwtxretries -- Display HW Transmit Retry Limit
get swtxretries -- Display SW Transmit Retry Limit
get rogueAPDetect -- Display Rogue AP Detection Mode
get rtsthreshold -- Display RTS/CTS Threshold
get shortpreamble -- Display Short Preamble Usage
get shortslottime -- Display Short Slot Time Usage
get sntpserver -- Display SNTP/NTP Server IP Address
get softwareretry -- Display Software Retry
get ssid -- Display Service Set ID
get ssidsuppress -- Display SSID Suppress Mode
get active -- Display Active (up) Mode
get station -- Display Station Status
get counters -- Display Tx/Rx Counters
get SuperG -- Display SuperG Feature Status
get systemname -- Display Access Point System Name
get tzone -- Display Time Zone Setting
get updateparam -- Display Vendor Default Firmware Update Pa
rams
get upsd -- Display UPSD Mode
get uptime -- Display UpTime
get vaps -- Display Number of Virtual APs
get vlan -- Display VLAN Operational State
get watchdog -- Display Watchdog Mode
get wds -- Display WDS Mode
get wirelessmode -- Display Wireless LAN Mode
get wmm -- Display WMM Mode
get wmmParamBss -- Display WMM parameters used by STA in thi
s BSS
get wmmParam -- Display WMM parameters used by this AP
get usrp -- Display the User Priority
get wlanstate -- Display wlan state
get xrpoll -- Display XR poll
get xrbss -- Display XR Bss Info
get xrFragmentThreshold -- Display XR fragment threshold
help -- Display CLI Command List
ping -- Ping
pktLog -- Packet Log
reboot -- Reboot Access Point
run -- Run command file
quit -- Logoff
exit -- Logoff
set 11gonly -- Set 11g Only Allowed
set 11goptimize -- Set 11g Optimization Level
set 11goverlapbss -- Set Overlapping BSS Protection
set acl -- Set Access Control List
set aging -- Set Aging Interval
set antenna -- Set Antenna
set authentication -- Set Authentication Type
set autochannelselect -- Set Auto Channel Selection
set beaconinterval -- Modify Beacon Interval
set burstSeqThreshold -- Set Max Number of frames in a Burst
set burstTime -- Set Burst Time
set cachePerf -- Begin cache performance monitoring
set calibration -- Set Calibration Period
set channel -- Set Radio Channel
set cipher -- Set Cipher
set countrycode -- Set Country Code
set ctsmode -- Set CTS Mode
set ctsrate -- Set CTS Rate
set ctstype -- Set CTS Type
set domainsuffix -- Set Domain Name Server Suffix
set dtim -- Set Data Beacon Rate (DTIM)
set enableANI -- Turn Adaptive Noise Immunity Control On/O
ff
set encryption -- Set Encryption Mode
set extendedchanmode -- Set Extended Channel Mode
set factorydefault -- Restore to Default Factory Settings
set firStepLvl -- Set ANI Parameter for FirStepLevel
set fragmentthreshold -- Set Fragment Threshold
set frequency -- Set Radio Frequency (MHz)
set gateway -- Set Gateway IP Address
set groupkeyupdate -- Set Group Key Update Interval (in Seconds
set hostipaddr -- Set Host IP address
set interVF -- Set Inter Vap Forwarding State
set intraVF -- Set Intra Vap Forwarding State
set ipaddr -- Set IP Address
set ipmask -- Set IP Subnet Mask
set jsw -- Set Jumpstart Mode
set jsp2Passwd -- Set JS-P2 password
set key -- Set Encryption Key
set keyentrymethod -- Select Encryption Key Entry Method
set keysource -- Select Source Of Encryption Keys
set login -- Modify Login User Name
set minimumrate -- Set Minimum Rate
set nameaddress -- Set Name Server IP address
set noiseImmunityLvl -- Set ANI Parameter for Noise Immunity Leve
l
set ofdmTrigHigh -- Set Higher Trigger Threshold for OFDM Phy
set ofdmTrigLow -- Set Lower Trigger Threshold for OFDM Phy
set ofdmWeakSigDet -- Set ANI Parameter for OFDM Weak Signal De
tection
set operationMode -- Set operation Mode
set password -- Modify Password
set passphrase -- Modify Passphrase
set pktLogEnable -- Enable Packet Logging
set power -- Set Transmit Power
set pvid -- Set the VLAN Tag
set radiusname -- Set RADIUS name or IP address
set radiusport -- Set RADIUS port number
set radiussecret -- Set RADIUS shared secret
set rate -- Set Data Rate
set reg -- Set Register Value
set hwtxretries -- Set HW Transmit Retry Limit
set swtxretries -- Set SW Transmit Retry Limit
set rogueAPDetect -- Set Rogue AP Detection Mode
set rtsthreshold -- Set RTS/CTS Threshold
set shortpreamble -- Set Short Preamble
set shortslottime -- Set Short Slot Time
set sntpserver -- Set SNTP/NTP Server IP Address
set softwareretry -- Set Software Retry
set ssid -- Set Service Set ID
set ssidsuppress -- Set SSID Suppress Mode
set active -- Set Active (up) Mode
set SuperG -- Super G Features
set systemname -- Set Access Point System Name
set tzone -- Set Time Zone Setting
set updateparam -- Set Vendor Default Firmware Update Params
set vaps -- Set Number of Virtual APs
set upsd -- Set UPSD Mode
set vlan -- Set VLAN Operational State
set watchdog -- Set Watchdog Mode
set wds -- Set WDS Mode
set wlanstate -- Set wlan state
set wirelessmode -- Set Wireless LAN Mode
set usrp -- Set the User Priority
set wmm -- Set WMM Mode
set wmmParamBss -- Set WMM parameters used by STAs in this B
SS
set wmmParam -- Set WMM parameters used by this AP
set xr -- Set XR
timeofday -- Display Current Time of Day
version -- Software version
wlan[0,0] ->
I can confirm that client mode is indeed possible in WGR614v7 with latest firmware. As mentioned above I had could login to the WGR614v7 telnet interface, I had updated the firmware to v 2.0.30 from this link http://support.netgear.com/app/answers/detail/a_id/2723/~/wgr614v7-firmw..." (enter your other router's MAC ID), I also did a "add remotewbr " (just in case, to add it as a remote wireless bridge). Then use ".." to goto main menu "save" then "reboot"
After telnet login, I used commands (without quotes) "wla", then "setoperation mode sta" (To enable mode as a wireless client, try using only setoperationmode to get a help list of options). I also did "find bss" to search for my other Belkin play max router, then copied its MAC ID and set it as the remote access point to connect to using command "set remoteap
From the web based netgear router configuration GUI (192.168.1.1) I changed the SSID to match the same SSID as the remote access point(router). Disabled the use DHCP option under LAN settings, disabled SPI firewall, disabled broadcast SSID, changed IP address of client netgear router to that just outside the remote router's DHCP list (192.168.2.101) (remote router had IP of 192.168.2.1) there should not be 2 DHCP on same network as it may lead to IP conflicts, kept both in the same subnet mask 255.255.255.0 . Also dropped any encryption initially on both routers for testing, which works, but also it seems to connect to each other using WEP enrcyption (64/128bit) which was set using the web GUI.
However I could not get client mode to work using WPA/WPA2 encryption. With WEP the WGR614v7 (the 1st LAN port of which) was connected to a Sony BRAVIA LED TV EX720 ethernet port could connect and surf the internet which was connected to the WAN port of the remote router.
