I am using NETGEAR " Wireless - G 54 Open Source Router KWGR614 " but I am facing one problem, could you please help me out.
Wireless router is working fine, I can browse internet but when the I try to open messenger that time the messenger is not signing in"
but when I connect direct to computer without using router through lan wire and try to sign in messenger, the messenger gets sign in.
Sometime after I plug out netgear and plug in netgear wire again, the messenger works for some time but then after some time it create same problem.
Kindly help me out on the same as to what setting I have to do.
Please I am beginner in setting process .. so it would be good if explain in detail on how to do it.
Waiting for your reply
Regards
Adil Kasmani
