Using the latest 18.7.10 big beta firmware
Followed these instructions:
http://www.dd-wrt.com/wiki/index.php/PPTP_Server_Configuration#PPTP
When I try to connect, it eventually times out verifying username and password. This is a bit further than I was getting, so I assume Ive got forwarding etc setup correctly. Displays Error:
I have my router connected to my adsl modem/router and setup as follows.
ADSL router 192.168.1.254
Forwarded ports 1723.& 1792 to th WAN address
WAN interface 192.168.1.64
3500L IP 192.168.2.1
Also forwarded the same ports to the 3500L IP
PPTP Server IP 192.168.2.2
Couldnt find the Loopback address that I have read needs to be disabled, but I think this issues was fixed with later releases.
Cant find any logs on the router to see if they can tell me anything...
Anyone got any advice???
