How could I load latest dd-wrt firmware?
3 posts / 0 new
tulsaOkRouter
tulsaOkRouter's picture
I have used
USB-TTL cable
and I got into the screen it says busybox v1.7.2
I was able to use ls, vi, cd.....commands but when I tried to use tftp and it said that I have to use tftp in octet mode.  I happened because I tried to get back to Netgear firmware but it did not get me back to there.  Can you some one give me some commands for me to get upload the latest dd-wrt firmware or netgear firmware.  I have the firmware ready but I don't know how to open the connection to transfer the firmware back.  I will let you see the screen later, probably I would my phone to try.
P.S if tftp octet mode would help I will do it.
tulsaOkRouter
I found this but my router
I found this but my router 192.168.1.1 can't ping my computer (192.168.1.2).  Can you please show the commands of busybox v1.7.2 to download the latest firmware from dd wrt or netgear?  I want my router to go back working condition as it was before.
Transfers a file from/to a tftp server using "octet" mode.
"Options:
        -l FILE Local FILE.
        -r FILE Remote FILE.
        -g      Get file.
        -p      Put file.
So try next:
tftp -g -r filename.txt 20.20.20.1             "
tulsaOkRouter
ls command I can see them in
ls command I can see them in folders apps but I don't know how to use them to get my router back to work.
etc
media
proc
sys
Castle
bin
include
mnt
sbin
tmp
www
dev
lib
opt
shares
usr
