How to restore with Original(Factory) firmware?
5 posts / 0 new
heo mu won
heo mu won's picture
Hi
I have a Nighthawk R8500 with
DD-WRT Kong Mod for NETGEAR R8500 (2017-11-04 CHK) installed.
I would like to remove that firmware and restore to a factory(Original) firmware.
I followed this link  to restore the firmware without luck.
I would appreciate some help.
josemald
josemald's picture
i also installed ddwrt on my
i also installed ddwrt on my R8500, it doesnt seem to support my VPN or it wont connect to it. Why does it allow installation of the Factory firmware? when flashing it does state successful but it opens back to ddwrt. can someone please help me get my router back to factory?
pcampan
pcampan's picture
This worked for me.
josemald
josemald's picture
actuall i got it to work by
actuall i got it to work by changing the setting in my ethernet adapter. i went in and type the same ip address as the router creating and conflict after saving it i went back in and replce ip with assign automaticly and then Genie pop up came and i was able to get the back back to factory. thanks for everyone help.
techelpp
techelpp's picture
I was also facing the same
I was also facing the same issue from a long time but I was not getting any solution for the same.
I followed the above-shared link and it solved my problem completely without an effort.
If you are having any issue regarding the virus, get it solved completely by clicking on the link shared below-
Kaspersky Customer Service
Zircon - This is a contributing Drupal Theme
Design by WeebPal.
