Later this month I'm moving and get fiber in to the flat.
My ISP is offering 100 mbit download and 10 mbit /IP and the ISP is giving me 5 IP's. Therefore I'm going to setup like the above to load balance my network and to get 100/60 instead of 100/10 wich is original if you only use 1 IP, but I will use all 5...
But I want to check how to setup my DD-WRT because I will use pfSense to do the magic for my network and I will only use my WNR3500L for hotspot (for friends) and WI-FI for my lappy and my gf...
Therefore my WNR3500L is after the switch, and will only host 2 laptops and friends laptops when they come to visit us!
Any solution how I fix this setup good?
Cheers
Kirill
Should be nop problem, just setup pfSense correctly to do the nat and then either configure dd-wrt to use static ip or dynamic ip through dhcp from your pfSense router
Will test this now this weekend to see if it will work :)
But in whick port, WAN or LAN port on the WNR3500L...
Edit: if you people lock at the picture, the WNR3500L is direct after the pfSense router, and not after the second switch :)
Old post, however you want to put DDWRT's LAN port on your LAN and then do not plug in the WWW port. We are doing something similar with ours, ZyXel firewall and Tomato, however we have 100Mbps in both directions using a fiber ring to Ethernet adapter (ATM.)
