Hi to all,
I am trying to add a guest network and im getting stuck with the drop down in set up/ networking/asign to bridge. I dont have this option:In the 2nd dropdown select wl0.1
I have ETH0, ETH1,ETH2, ETH3 WLAN1 and WLAN2. Did I do something wrong or what should i use?
I gues my question is:for a Netgear R8000 FlashRouter. what is The virtual interface for the 2.4GHz network?
Search for Kongs instructions. And you will also have to add a firewall rule.
