Issue - 2018-2-15 BIN - Router Goes on the Fritz
7 posts / 0 new
nathanielhatten
nathanielhatten's picture
I was on a 12/2017 version with only 1 or 2 reset due to power outages in the past 5 months. Installed 2018-2-15 BIN and have to restart the router 3 times now. It just drops WiFi, and when you try to connect it says wrong ID / password until I reset it. LAN just disappears as well.
Any thoughts on what I should try to resolve it?
-N.
e38BimmerFN
e38BimmerFN's picture
Do a factory reset and set up
Do a factory reset and set up from scratch.
Does this happen with OEM FW installed?
Try Voxels FW to see as well...
VicB
VicB's picture
Same happens to me, maybe 2x
Same happens to me, maybe 2x a week.  A router reboot seems to fix it.  I'm considering scheduling the router to reboot on a daily basis to prevent this.
e38BimmerFN
kbp
kbp's picture
Build 2018-15 (R7800) is
Build 2018-15 (r7800) is "borked". My radios drop everyother day also. My R7000 works just fine on the laterst Kong Build. I have been working with DD-WRT builds going back many years and this build has radio problems.
What I am wondering is if anyone has gone back to the original build and is it stable? Untill a new build comes forth I am forced back to the stock netgear firmware on my r7800. I check-back every few weeks looking for a newer "Kong" build but no joy as of yet.
And as of now I am not yet ready to try Voxels FW just yet. I am so accustom to DD-WRT.
e38BimmerFN
Go back to last working
Go back to last working version?
MrMad1966
MrMad1966's picture
That build did the same for
That build did the same for me. I factory reset with switch on router, used factory password to gain access again then reflashed newer test 4.9 kernal. Happily all my original settings intact. Good luck
