Kong DD-WRT questions about adding features and Netgear R7000 router
4 posts / 0 new
hulltech63
Does DD-WRT have hardware acceleration and will it work with fiber optic providers. I would like to get the best DD-WRT from Kong and try it out if it works.  I have no idea how to install DD-WRT installation on my Netgear R7000 router. I would like the latest version that is available and stable release.  There is a website that will bypass survey s.
Survey-remover.com. It has a JavaScript you can add to block surveys and a paid version to add a key. It is under the Xjs survey remover bookmarklet. You cannot be too unprepared with the internet.
Any help is greatly appreciated,
Have a great day!
hulltech63
hulltech63
Anyone?
Anyone?
hulltech63
Well, right now I switched to
Well, right now I switched to the Kong build of 24500 yesterday due to my vpn not able to connect with Openvpn client. I am trying to troubleshoot problems with them on the router setup with their vpn services but I have no clue to Linux commands. My vpn is cryptostorm.is and I have been using a widget to connect before I switched firmware to DD-WRT on my router.when the vpn has an error. It drops traffic and I have to reset it.any ideas anyone.
hulltech63
I tried three different
I tried three different versions of DD-WRT, the Kong 2400 ,24500 and the std old version and all of them couldn't connect to my openvpn client but their Windows app was able. I am not a Linux person so I switched back to Netgear firmware.
I would like to ask if it is possible to add additional features to DD-WRT firmware in the future. A basic settings tab and advanced settings tab like Netgear firmware has for
Individuals who do not know what they are doing.
A proxy server addition to help stop dnsleak so there IP will not be shown. The JavaScript from Xjs survey remover to bypass surveys.
Thank You for your hard work Kong.
Hulltech63
