Hi all,
I'm currently running a WNR3500Lv2 as my main router with Shibby v110-AiO Tomato Firmware. It's connected to the internet via a Cisco modem; my internet connection offers me 100Mbit/s download and 5Mbit/s upload speed. There is no problem with throughput - I can easily reach 120MByte/s on a local network (transfer between my NAS and my Workstation); also, I don't have any problems, if the servers on the internet allow it, to reach full speed (which is about 105Mbit/s).
However, my router gets unresponsive whenever I download at full speed (everything above 7MByte/s). The download doesn't get interrupted, but I can't browse any websites or make any new connections, as long as the download is running. As soon as it is finished, everything works fine again. The router webinterface is also unreachable during that time.
QoS is disabled, so is bandwith logging and other RAM-consuming stuff. I got about 110MB of free RAM, and about 8000 free NVRAM left on the router. When I look up the webinterface after the download has finished, it says, that CPU loadtime is at about 5% for the last 1 min. There doesn't seem to be a CPU limitation; I guess, there is some kind of a loop or something like that. Does someone have a 100Mbit/s+ setup, which runs fine at full speed, without any problems? Or does someone even experience the same problems?
Looks like a bad flash, did that to my router (Same as you) my only way to recover it was to use a serial ttl USB cable. You'll have to open your router and connect the cable through the serial port inside.
http://m.ebay.com/itm?itemId=270694777675
there is a guide here how to do the recover
Hope that helps.
Hi there!
Well, I actually had a bad flash and I've successfully recovered it once with a TTL Cable (I got a modded Nokia Datacable, which worked absolutely fine!). However, I dont have any problems now with the flash. The lock ups seem to be due to overloading. Still; my router is working atm. Can't I just reflash via the Webinterface? Or do I really have to open up the router and flash via TTL?
Thank you in advance!
I've comment in the wrong post. It was suppose to go here
http://www.myopenrouter.com/forum/thread/53400/Accidentally-flashed-non-...
Sorry i have no thoughs on your issue, unless you try the 114 onwards build which has a new driver incorporated into the WAN port
take a look here
http://repo.or.cz/w/tomato.git/commit/4d5b6d701f498b490d9e279cb33c1eda4f...
and here
http://tomato.groov.pl/?p=450
