I'm not even sure where to start to search. I've search a lot! It's driving me insane so I just have to post!
By the way, I'm pretty noob so great DIY guide would help or response...
I just got a Netgear WNR3500L, I installed:
Firmware: DD-WRT v24-sp2 (08/07/10) std-usb-ftp
Now when I go to services > usb, no matter what combination of choices I choose, I cannot get the HD to mount.
It's a WD HD, 1TB formatted for Mac. I store my movies and time machine on it (2 different partitions)
--- /dev/discs/disc0/disc
Block device, size 931.5 GiB (1000204886016 bytes)
DOS/MBR partition map
Partition 1: 931.5 GiB (1000204885504 bytes, 1953525167 sectors from 1)
Type 0xEE (EFI GPT protective)
GPT partition map, 128 entries
Disk size 931.5 GiB (1000204886016 bytes, 1953525168 sectors)
Disk GUID 0F943AE9-6813-E140-A3C0-18EB138EB12C
Partition 1: 200 MiB (209715200 bytes, 409600 sectors from 40)
Type EFI System (FAT) (GUID 28732AC1-1FF8-D211-BA4B-00A0C93EC93B)
Partition Name "EFI System Partition"
Partition GUID DB0BCD51-5F6D-D841-98DB-2E3D95502A6E
FAT32 file system (hints score 5 of 5)
Volume size 196.9 MiB (206472192 bytes, 403266 clusters of 512 bytes)
Volume name "EFI"
Partition 2: 183.0 GiB (196505247744 bytes, 383799312 sectors from 409640)
Type Mac HFS+ (GUID 00534648-0000-AA11-AA11-00306543ECAC)
Partition Name "Untitled"
Partition GUID 5F57C66D-2EDA-3845-A48C-79D5B2C84F82
Partition 3: 748.1 GiB (803221446656 bytes, 1568791888 sectors from 384471096)
Partition GUID B3A2B7DB-43E3-0948-8759-C7FBF4319788
Partition 4: unused
Status: Not mounted
Please help me make that say "Status: Mounted"
EFI Partitions aren't supported. You should use use a linux tool like parted/qparted to create two partitions one ext3 and one hfs+ for your mac.
