Ok, please please bear with me. I been fight with my ips and ATT
to get my network back up.
Background
I had DSL. The company I am with, started me out on a ADSL that they
set up with my block of ip's. I have 16. 13 that I can use. One lost
to Network, Boardcast, and the gateway. On friday, I move from my old
little house to my new big house which has IFITL (Integrated Fiber In The Loop Because of this, I can't no longer use my modem. I had to purchase the netgear router because it support PPPoE, no
problem, most due. Here where the problem because. I can connect to my
ISP and I get my WAN ip, and I can get out, because NAT'ing is turn
on, but I can't get in. I can't ping my GATE. No If I turn NAT'ing off I can't get in or out.
Problem
Let me explain a bit about my network, I hope this helps and doesn't
confuse everyone. I will change the ip's for safety reason. But you
should be able to follow along. My router is a Linksys, it might be
the problem. I got in and set it up for PPPoE with my user id and password. I connect I get the wan ip of 47.216.14.229, Now I give my router the ip of 47.216.17.87 with asubnet of 255.255.255.240. Now my boxes are on the same 47.216.17.86/28
network. I go in the router and turn off NAT'inng. I
can from my linux box ping 47.219.14.229
but I can't ping any thing
belong it.
The Questions...
Does anyone know know how I can get the work to see my gateway 47.216.17.89? Or a way that I can get my network back up? I got a static route but does doen't help. Should I flash my route with the DD-WRT. I down want the world to see my wan IP because it does no good for my network. What I need is the world to see my network 47.216.17.86/28. No DMZ, No NAT'ing. Just my network.
I know it weird to ask this list, but I am at a lost. My websites, no
email and wife that doesn't understand that some times these things
take a bit of work.
Thanks a head of time.
Payne
