I've looked through every setting to find the mac address of any computer or network adapter that's connected to my dsl. It's no where to be found, can someone help?
Hi, on the left hand side click on "Attached Devices" link under "Maintenance" section.
You will find a complete list showing IP addresses, Device names and MAC addresses of your connected devices.
thanks, one more thing. on block sites i can only add one trusted ip address that can visit block sites, how do i add more than 1?
Hi, everytime you add new "Keyword" and click the "Add Keyword" button located below the input area/textbox, it will be saved and displayed on the list/multiline textbox below this button.
I meant the ip address not the keyword. below the keyword section where it says "allow trusted ip address to visit blocked sites"... any ideas?
Hi, it seems that only one computer in your network will be able to access all the blocked content/sites...
