So im trying to create a seperate wifi virtual interface, and its not working fo rme.. Is this a flaw of this firmware? None of the wireless adapters are showing as an option in to assign them to a bridge either? I only see ETH0-3 which apears to be the wireless stuff.. I would expect to see wl0-3 and wl0.1 etc. Any ideas?
I've used eth1-3 and it works although I'm battling WiFi stability on the 5GHz radios.
Eth1-5ghz
Eth2-2.4ghz
Eth3-5ghz
I found that rebooting the router after creating the virtual interface will get it to start transmitting.
