Hi all !
I'm a beginer and I'm trying to setup correctly my wnr3500L (v1).
I installed ddwrt K2.6 on.
I plugged the wnr just behind my internet box (bridge mode). But when I plugged the cable between the wnr and my switch, I had no internet access on computers (dhcp was on).
So I tried to set the wnr static ip adress in another range : 192.168.0.99
Computer now have internet access, but I can't access to the wnr anymore
I tried to tape "http://www.192.168.0.99" with diferent browsers but there is no access at all.
Is that normal ? do you know what is wrong ? Thanks for your help :)
