I am VERY Frustrated and dont know what I am doing wrong I have a Netgear C3700 Cable Modem... and I have a WNR3500L Router HArd Wired to it in another room. I want to set up the router to use the SAME SSID I have Tomatoe Ver 12.8 Shibby installed on the router.
I am not able to set up the router to use the same SSID without somthing not working. I dont know what the right term to search for to find a correct tutorial. Is is Wireless Bridging, Access Point , WDS?
I can set the Router with a different SSID and DHCP turned on but if I try to turn off DHCP and have the modem do it, I get errors.
Would appreciate anyones help. I can change the Firmware or whatever is needed just need to know what to look for.
Thank YOu
