hallo every body i have a probleme with my router netgear wnr3500 v2
when i turn it on , the on/off led stay green and the wirless led stay blue
it won't to connect with the router and pc.
please help me.
please help me.
Please mention which firmware are you using ??
the firmware of my router is U12H127T02
Help me please?
Are you using Stock firmware or any Opensource firmware (ddwrt,tomato)??
I don't now because i bought it like this. how can I know that?
Ok that means you are using stock firmware. Actually the firmware that the router comes with is called Stock firmware.
Are you trying to connect with Ethernet or wireless ??
Please check your network connection settings at your PC.
I connected it with several pc but it does not connect and no LED lights except, the first two ( on/off led and wirless led ), the same problem with the connection router / modem. And I look over wifi with my iphone, but I find nothing.
I personally don't have a WNR3500v2. Do you have Wirelss on/off button? If yes then check it's status (on/off).
Ok, do you now how can i flash it with usb/serial TTL cable.
