Questions about WGR614Lv8 WW (World Wide) Model
4 posts / 0 new
teamworker
I use dd-wrt 11218 miniBuild (2,8MB) on my 614Lv8 WW Model.
This build has no openvpn Services integrated.
Only the unsecure PPTP
Q1:
I have read, 614Lv8 WW not the NA Model  can't install *.bin files with the GUI from dd-wrt.
WW 614Lv8 Model can only use *.chk files, per tftp to upgrade
Is that right?
There is no Std/smal 11218.chk in Elko's new builds, only Std/Smal *.bin for 614Lv8 .
Q2:
rename Std/smal *.bin in *.chk is that a way?
thnx for Anwers.
Greetings Teamworker
teamworker
Big thx to Tathagata Das
Please read my BIG Problem under:
http://www.myopenrouter.com/forum/thread/10766/vmlinuz-Problem/
billy
tryin to use my netgear
tryin to use my netgear router but lost my netgear cd
achilles
billy said:
It is not clear from your post why do you need the CD .... the reset button on the board can be used to get back factory defaults .
Then you can access board's GUI at 192.168.1.1 and configure the board as per your need
