Hi all,
I'd posted this in one of the hot topic threads, but I thought it maybe easier to start a new thread. So here it is.
I'm a total newbie on DD-WRT and I just got a new external HD (WD My Book 4TB USB 3.0/USB 2.0) today. Hooked it up to my r7000 with netgear's default firmware and it works right away, but I realized that as soon as I connected the drive to the r7000, my wifi became very unstable. So after doing some research online, I found that others also reported wifi issue with usb3 on the default firmware, so I decided to try out Kong's firmware.
After reading a bit about Kong's firmware, I flashed the r7000.chk firmware and then updated it to the latest 247100M build. After rebooting the router, I was able to see the USB drive showed up under Services > USB > Disk Info (it's still in NTFS format, I did not touch it but just plugged into the router directly after I got it.)
Disk Info:
--- /dev/sda1
Block device, size 3.639 TiB (4000751550464 bytes)
Windows NTLDR boot loader
NTFS file system
UUID A2CA0AEBCA0ABC13
Volume size 3.639 TiB (4000751546368 bytes, 976745983 sectors of 4 KiB)
/dev/sda1 mounted to /tmp/mnt/sda1
Then I went to the NAS tab, Enabled Samba Server, I'm not sure what to put in the Server String field, so I just put r7000. Left the Workgroup field blank. Under File Sharing, I added an item with the following information:
Path: /mnt/sda1 (selected from the dropdown list)
Subdir: blank
Name: ShareDrive (I just made this name up)
Public: checked
Access: Read/Write
After saving the configuration, I still couldn't see the drive come up in the Window Explorer. Any advice is appreciated. Thank you!
I think workgroup field must be filled with the one of your LAN. I mean if you require to access from a win machine it should be the same. Usually default to WORKGROUP.
Thanks for the respond.
I also tried to put WORKGROUP in the workgroup field, however ever since I switched to win7, I didn't see the setting for workgroup on it anymore. It only has Homegroup. So putting WORKGROUP in the field still won't let the drive show up on my network list.
Problem solved.
Turned out the shared drive will not automatically display under Network drive, but if I typed in the exact path \\router IP\sharedrive, then it will open up the drive right away.
