R8000 Bootloop (possible brick)
4 posts / 0 new
aiziks251
aiziks251's picture
Hey Everyone,
I just got my R8000, booted it up, loaded on tomato (init -> AIO), spent some time setting up the following:
  • Static IP
  • Static DHCP
  • dnsmasq
  • vlan / guest wifi network
Everything seemed to be working fine (though the last thing I added was the vlan, I might not have rebooted right after I added that).  I unplugged it from my computer and added it to my network as the primary router.
It immediately entered into a bootloop.  I tried all the tools I had available to me, from holding down the reset button to yelling at it, to sulking, disconnecting it from the network and plugging it directly into my laptop again.  Nothing seemed to work (although yelling made me feel better temporarily).
I went online and saw that some people had bootloops issues with the r7000 if they put it into client-bridge mode.  I was pretty sure I didn't do that, but it was bootlooping, so I looked up the fix for that.  Bought a usb/ttl cable and waited.  Today my cable came and after carefully taking this monster apart (including that pesky hidden screw) I managed to connect up the 3 pins (ground, tx, and rx) to the board.  I had tx and rx wrong though, so then I had to swap them.  Finally, after much googling I was getting input on my screen showing my router failing in real time!
I spammed crtl-c, interrupted the bootup, a prompt!  I checked the wlans to see if any of them were in client bridge... none, apparently that would be too easy.
I then figured, what the hell, let's just reflash it back to stock.  And that's what I did.  That first bootup was a wild ride, all kinds of new info on the screen, skipping merrily along where I believe it had failed previously.  Then... it rebooted, and rebooted, and rebooted... bootloop still.
I googled, I reflashed, I googled, I reflashed.  I am out of ideas.  I'm not sure what I did to brick it, and I'm not sure what I can do to unbrick it.  Any ideas you all have would be much appriciated.
Below is the log of my boot sequence.  If you need anything else just ask.
Digital core power voltage set to 1.0V
Decompressing...done
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S300001EB
000014B0
RDLYW0 00000004
RDENW0 00000037
RDQSW0
    0000000000111111111122222222223333333333444444444455555555556666
    0123456789012345678901234567890123456789012345678901234567890123
 00 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------
 01 -------++++++++++++++++++++++++++X++++++++++++++++++++++++++----
 02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------
 03 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
 04 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------
 05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----
 06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------
 07 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++--
 08 -------+++++++++++++++++++++++X++++++++++++++++++++++-----------
 09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++
 10 ---------+++++++++++++++++++++++X+++++++++++++++++++++++--------
 11 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--
 12 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------
 13 --------------+++++++++++++++++++++++X++++++++++++++++++++++----
 14 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
 15 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--
P\00\00\00W0
 00 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------
 01 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----
 02 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------
 03 -+++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------
 04 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
 05 --+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----
 06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
 07 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--
 08 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------
 09 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++
 10 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------
 11 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--
 12 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------
 13 ----++++++++++++++++++++++++++++X+++++++++++++++++++++++++++----
 14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
 15 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--
N\00\00\00W0
 02 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------
 03 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------
 04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------
 07 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-
 08 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
 10 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
 11 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-
 12 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
 13 ---------------++++++++++++++++++++++++X++++++++++++++++++++++--
 14 -----------++++++++++++++++++++++++X++++++++++++++++++++++++----
 15 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++
WRDQW0
 00 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-
 01 ++++++++++++++++++++++++++X+++++++++++++++++++++++++---------++-
 02 +++++++++++++++++++++++++X++++++++++++++++++++++++--------+++++-
 03 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-
 04 +++++++++++++++++++++++X++++++++++++++++++++++-----------++++++-
 05 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-----++++++-
 06 +++++++++++++++++++++++X+++++++++++++++++++++++----------++++++-
 07 +++++++++++++++++++++++++X+++++++++++++++++++++++++---------+++-
 08 +++++++++++++++++++++++X+++++++++++++++++++++++-+--------++++++-
 09 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
 10 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-
 11 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------
 12 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------+++++-
 13 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------
 14 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-
 15 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------
WRDMW0 00000024
WRDMW0 00000026
ADDR
 00 ++++++++++++++++++++S++++++++++X++++++++++++++++++++++++++++++++
CFE for Foxconn Router R8000 version: v1.0.8
Build Date: Fri May 30 15:03:06 CST 2014
Init Arena
Init Devs.
Boot up from NAND flash...
Bootcode Boot partition size = 524288(0x80000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytes
Device eth0:  hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0
Checking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)
Loading: .... 4218016 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
console [ttyS0] enabled, bootconsole disabled
brd: module loaded
loop: module loaded
lookup_nflash_rootfs_offset: offset = 0x200000
nflash: squash filesystem with lzma found at block 29
0x000000200000-0x000004200000 : "linux"
0x0000003ad160-0x000004000000 : "rootfs"
0x000002200000-0x000002240000 : "board_data"
PPTP driver version 0.8.5
=== PPTP init ===
u32 classifier
    Actions configured
nf_conntrack version 0.5.0 (3990 buckets, 15960 max)
ctnetlink v0.93: registering with nfnetlink.
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
Registering the dns_resolver key type
NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)
(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
0x000004000000-0x000008000000 : "brcmnand"
devtmpfs: mounted
Freeing init memory: 216K
Hit ENTER for console...
emf: module license 'Proprietary' taints kernel.
et_module_init: txworkq set to 0x0
et_module_init: et_txq_thresh set to 0x400
et_module_init: et_rxlazy_timeout set to 0x3e8
et_module_init: et_rxlazy_framecnt set to 0x20
fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.40 (r527781)
fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.40 (r527781)
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.40 (r527781)
dhd_module_init in
dhd_queue_budget = 256
dhd_sta_threshold = 2048
no wifi platform data, skip
PCI_PROBE:  bus 1, slot 0,vendor 14E4, device AA52(good PCI location)
PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
DHD: dongle ram size is set to 983040(orig 983040) at 0x180000
dhd_attach: ctf_attach() failed
dhd_attach(): thread:dhd_watchdog_thread:2f2 started
dhd_deferred_work_init: work queue initialized
Dongle Host Driver, version 1.194.33 (r526004)
Compiled in drivers/net/wireless/bcmdhd on Jun 17 2015 at 11:27:36
Register interface [eth1]  MAC: 00:90:4c:11:22:33
dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-chkd2hdma-proptxstatus, 2015.06.17.111523, 2015/06/17 11:15:23).
dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.
dhdpcie_readshared: address (0xfe0d01f2) of pciedev_shared invalid
Waited 5006383 usec, dongle is not ready
dhd_bus_init :Shared area read failed
dhd_bus_start, dhd_bus_init failed -1
Enforcing kernel panic
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = cf914000
[00000000] *pgd=8f164031, *pte=00000000, *ppte=00000000
Internal error: Oops: 817 [#1] PREEMPT SMP
last sysfs file: /sys/kernel/uevent_seqnum
module:  dhd bf024000 799274
module:  et bf011000 48925
module:  igs bf009000 11927
module:  emf bf000000 15169
Modules linked in: dhd(+) et(P) igs(P) emf(P)
CPU: 1    Tainted: P             (2.6.36.4brcmarm #5)
PC is at dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd]
LR is at dhdpcie_bus_process_mailbox_intr+0x17c/0x1e8 [dhd]
pc : [<bf037440>]    lr : [<bf037460>]    psr: 20000013
sp : cf079cf8  ip : c0435ee4  fp : 00000000
r10: c003c1d4  r9 : c043bf20  r8 : c0440cd8
r7 : bf052d00  r6 : 00000000  r5 : 00000100  r4 : cf809000
r3 : 00000000  r2 : cf078000  r1 : 60000013  r0 : 00000019
Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c53c7d  Table: 8f91404a  DAC: 00000015
Process insmod (pid: 752, stack limit = 0xcf078270)
Stack: (0xcf079cf8 to 0xcf07a000)
9ce0:                                                       00000000 cf809000
9d00: 00000000 b83ef180 cf078000 cf809000 00000100 00000000 cf078000 bf047d08
9d20: 00000100 3b9aca00 cf29c000 cf29f898 00000000 bf02924c cf29f894 c006955c
9d40: c0069450 0000000b c03ec058 cf078000 00000101 c003c148 c03ec040 c043bf20
9d60: 00000001 c03ade10 00000033 cf29c008 00000006 0000000a cf29c008 60000013
9d80: cf29c000 bf052d00 cf29c008 00000000 00000033 ffffffff 00000000 c0069a38
9da0: cf078000 c0069c44 cf29c008 bf02c890 00001788 cf0ac204 cf9e4000 cf9e4000
9dc0: cf0ac1e0 cf006cc0 cf809000 bf061000 000007f8 bf048f80 0000aa52 c017ccd4
9de0: cf9e4000 cf9e4000 00000000 bf056ee8 bf048d6c c017cea4 c017ce48 c0443c68
9e00: bf056f18 cf9e4060 bf056f18 c019a124 cf9e4060 bf056f18 cf9e4094 00000000
9e20: bf061000 c019a2ac bf056f18 cf079e38 c019a220 c0199380 cf8cc280 cf9ba758
9e40: cf8cc250 bf056f18 c03fd1c8 cf0ac180 00000000 c0199a78 bf0506e4 c0165140
9e60: cf8cc240 bf056f18 bf056f18 c03fd1c8 00000000 bf061000 000007f8 c019a4b0
9e80: bf056ee8 bf056f18 c03fd1c8 00000000 bf061000 c017d10c 00000001 00000000
9ea0: c040e000 cf078000 00000000 bf038a54 00000001 00000000 c040e000 bf0610f8
9ec0: bf057010 c003e5bc 000007f8 c039de48 000000cb cf007ba0 00000000 bf057010
9ee0: bf056fc8 bf057010 bf056fc8 cf214770 cf214400 00000000 000007f8 c00918a0
9f00: bf056fd4 4017b6a8 c00902c4 bf0570fc c043beec cf078000 d0c24578 00064008
9f20: cf004788 d0b71000 000ca494 d0c288ac d0c28677 d0c2cb84 cf039000 00034af8
9f40: 00037478 00000000 00000000 00000031 00000032 00000028 0000002c 00000019
9f60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c03bb608
9f80: 00000003 0006c9f8 4020e008 00064008 00000080 c003ec68 cf078000 00000000
9fa0: 00000000 c003eac0 0006c9f8 4020e008 4020e008 000ca494 00064008 00000000
9fc0: 0006c9f8 4020e008 00064008 00000080 00000000 00000000 00060e7c 00000000
9fe0: 401199a0 be858c04 000123b4 401199b0 20000010 4020e008 00000000 00000000
[<bf037440>] (PC is at dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd])
[<bf037440>] (dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd]) from [<bf047d08>] (dhd_bus_dpc+0xc8/0x150 [dhd])
unwind: Index not found bf047d08
Code: e5973000 e3130001 1a000006 e3a03000 (e5833000)
---[ end trace 58ecc25d2de7d3eb ]---
Kernel panic - not syncing: Fatal exception in interrupt
[<c0044ff8>] (unwind_backtrace+0x0/0xf8) from [<c02ed358>] (panic+0x7c/0x1a8)
[<c02ed358>] (panic+0x7c/0x1a8) from [<c00426f8>] (die+0x1ac/0x1dc)
[<c00426f8>] (die+0x1ac/0x1dc) from [<c0046390>] (__do_kernel_fault+0x6c/0x8c)
[<c0046390>] (__do_kernel_fault+0x6c/0x8c) from [<c0046500>] (do_page_fault+0x150/0x1ec)
[<c0046500>] (do_page_fault+0x150/0x1ec) from [<c003e3a4>] (do_DataAbort+0x30/0x9c)
[<c003e3a4>] (do_DataAbort+0x30/0x9c) from [<c03ad46c>] (__dabt_svc+0x4c/0x60)
Exception stack(0xcf079cb0 to 0xcf079cf8)
9ca0:                                     00000019 60000013 cf078000 00000000
9cc0: cf809000 00000100 00000000 bf052d00 c0440cd8 c043bf20 c003c1d4 00000000
9ce0: c0435ee4 cf079cf8 bf037460 bf037440 20000013 ffffffff
[<c03ad46c>] (__dabt_svc+0x4c/0x60) from [<bf037440>] (dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd])
CPU0: stopping
Rebooting in 3 seconds..[<c0044ff8>] (unwind_backtrace+0x0/0xf8) from [<c003e334>] (do_IPI+0x114/0x154)
[<c003e334>] (do_IPI+0x114/0x154) from [<c03ad4c8>] (__irq_svc+0x48/0xe8)
Exception stack(0xc03ebf78 to 0xc03ebfc0)
bf60:                                                       00000002 cf9f7600
bf80: c03ebfc0 00000000 c03ea000 c040e0a8 c03f6b80 c03f6b78 80000000 413fc090
bfa0: 0000001f 00000000 00000000 c03ebfc0 c003fbe4 c003fbe8 60000013 ffffffff
[<c03ad4c8>] (__irq_svc+0x48/0xe8) from [<c003fbe8>] (default_idle+0x24/0x28)
[<c003fbe8>] (default_idle+0x24/0x28) from [<c003fd88>] (cpu_idle+0x70/0xa4)
[<c003fd88>] (cpu_idle+0x70/0xa4) from [<c0008e8c>] (start_kernel+0x3cc/0x42c)
[<c0008e8c>] (start_kernel+0x3cc/0x42c) from [<80008148>] (0x80008148)
SHMOO VER 1.13
S300001EF
000014E0
RDLYW0 00000004
RDENW0 00000037
RDQSW0
 01 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----
 06 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------
 07 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++--
 10 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------
 11 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--
 12 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
 13 ---------------++++++++++++++++++++++X++++++++++++++++++++++----
 15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--
P\00\00\00W0
 01 --+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----
 02 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
 05 -+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----
 07 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--
 15 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--
N\00\00\00W0
 01 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++---
 07 ---------+++++++++++++++++++++++++++X++++++++++++++++++++++++++-
 10 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
 12 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------
 13 ---------------++++++++++++++++++++++++X+++++++++++++++++++++++-
 14 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----
 15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++++
WRDQW0
 01 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-
 02 ++++++++++++++++++++++++X++++++++++++++++++++++++-+-------+++++-
 03 +++++++++++++++++++++++++X++++++++++++++++++++++++--------+++++-
 07 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-
 08 ++++++++++++++++++++++++X++++++++++++++++++++++++---------+++++-
 12 +++++++++++++++++++++++++X++++++++++++++++++++++++--------+++++-
 14 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-
WRDMW0 00000024
WRDMW0 00000026
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Startup canceled
CFE> ^C
CFE> tftpd
Start TFTP server
Reading :: Done. 31223866 bytes read
Programming...done. 31223866 bytes written
Skip writing CHK checksum for nflash.
SHMOO VER 1.13
S300001E7
000014C0
RDLYW0 00000004
RDENW0 00000037
RDQSW0
P\00\00\00W0
 01 -+-++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----
 03 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------
 04 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------
 10 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
 11 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--
 13 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----
N\00\00\00W0
 00 ---++++++++++++++++++++++++++X+++++++++++++++++++++++++---------
 08 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
 09 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++
 13 ----------------++++++++++++++++++++++++X+++++++++++++++++++++--
WRDQW0
 00 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-
 01 ++++++++++++++++++++++++++X++++++++++++++++++++++++++--------++-
 05 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-
 07 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-
 08 ++++++++++++++++++++++++X++++++++++++++++++++++++--------++++++-
 12 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-
 13 --+++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
 15 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------
WRDMW0 00000024
WRDMW0 00000026
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Loading: ..... 4982560 bytes read
Entry at 0x00008000
Closing network.
brd: module loaded
loop: module loaded
nflash: squash filesystem with lzma found at block 31
Creating 17 MTD partitions on "nflash":
0x000000200000-0x000002600000 : "linux"
0x0000003eef20-0x000002600000 : "rootfs"
0x000002600000-0x000002680000 : "board_data"
0x000002680000-0x000002780000 : "POT1"
0x000002780000-0x000002880000 : "POT2"
0x000002880000-0x000002b40000 : "T_Meter1"
0x000002b40000-0x000002e00000 : "T_Meter2"
0x000002e00000-0x000002e80000 : "ML1"
0x000002e80000-0x000002f00000 : "ML2"
0x000002f00000-0x000002f80000 : "ML3"
0x000002f80000-0x000003000000 : "ML4"
0x000003000000-0x000003080000 : "ML5"
0x000003080000-0x000003100000 : "ML6"
0x000003100000-0x000003180000 : "ML7"
0x000003180000-0x000003200000 : "QoSRule"
PPPoL2TP kernel driver, V0.17
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:0b.1: EHCI Host Controller
ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci_hcd 0000:00:0b.0: OHCI Host Controller
ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
xhci_hcd 0000:00:0c.0: xHCI Host Controller
xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3
xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000
xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
usb usb3: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
xHCI xhci_add_endpoint called for root hub
xHCI xhci_check_bandwidth called for root hub
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
csw_retry 100
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
u32 classifier
    Actions configured
nf_conntrack version 0.5.0 (3979 buckets, 15916 max)
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
sit0: Disabled Privacy Extensions
ip6tnl0: Disabled Privacy Extensions
Creating 2 MTD partitions on "brcmnand":
0x000003200000-0x000007b00000 : "brcmnand"
0x000007b00000-0x000008000000 : "OpenVPN"
SQUASHFS error: Xattrs in filesystem, these will be ignored
devtmpfs: mounted
Freeing init memory: 220K
[sighandler]: No more events to be processed, quitting.
[cleanup]: Waiting for children.
[cleanup]: All children terminated.
Reading board data...
WSC UUID: 0xec7c03e1ee919e563d3eda60c7413130
NTP synchronized date/time: Wed Feb  4 09:01:44 2004
MAC address of 1st STA connected: 00-00-00-00-00-00
No RF parameters! Use default.
### main:1520 Set Normal Power!
ctf: module license 'Proprietary' taints kernel.
Initialise conn table 2048 entries
Commit new ethernet config...
Doing nvram commit by pid 1 !
fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)
fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)
dhd_module_init in
PCI_PROBE:  bus 3, slot 0,vendor 14E4, device AA52(good PCI location)
PCI: Enabling device 0002:03:00.0 (0140 -> 0142)
dhd_attach(): thread:dhd_watchdog_thread:2985 started
dhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0
dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)
Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49
dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).
PCIe shared addr read took 46383 usec before dongle is ready
DMA RX offset from shared Area 0
bus->txmode_push is set to 0
ring_info_raw: 56
4c 92 26 00 dc 9a 26 00 f4 9c 26 00 0c 9f 26 00
18 9f 26 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 86 00 00 00
max H2D queues 134
dhd_bus_start: Initializing 134 flowrings
dhd_bus_cmn_writeshared:
  0000: 00 00 7a 8d 00 00 00 00
  0000: 00 a0 35 8e 00 00 00 00
  0000: 00 24 0f 8f 00 00 00 00
  0000: 00 80 44 8d 00 00 00 00
  0000: 00 c0 35 8e 00 00 00 00
  0000: 00 e0 35 8e 00 00 00 00
  0000: e0 94 13 8d
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 75
PCI_PROBE:  bus 4, slot 0,vendor 14E4, device AA52(good PCI location)
PCI: Enabling device 0002:04:00.0 (0140 -> 0142)
dhd_attach(): thread:dhd_watchdog_thread:2988 started
Register interface [eth2]  MAC: 00:90:4c:11:22:33
CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crc
CONSOLE: 000000.035 wl0: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)
CONSOLE: 000000.035 TCAM: 256 used: 135 exceed:0
CONSOLE: 000000.036 reclaim section 1: Returned 119324 bytes to the heap
CONSOLE:
ring_info_raw: 56
28 8f 26 00 b8 97 26 00 d0 99 26 00 e8 9b 26 00
f4 9b 26 00 00 00 00 00 00 00 00 00 00 00 00 00
max H2D queues 134
  0000: 00 80 fe 8c 00 00 00 00
  0000: 00 a0 03 8d 00 00 00 00
  0000: 00 0c 0f 8f 00 00 00 00
  0000: 00 c0 51 8d 00 00 00 00
  0000: 00 c0 03 8d 00 00 00 00
  0000: 00 e0 03 8d 00 00 00 00
  0000: a0 d7 68 8d
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 74
dhd_attach(): thread:dhd_watchdog_thread:298b started
Register interface [eth3]  MAC: 00:90:4c:11:22:33
CONSOLE: 000000.041 wl1: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)
CONSOLE: 000000.041 TCAM: 256 used: 135 exceed:0
CONSOLE: 000000.042 reclaim section 1: Returned 119324 bytes to the heap
CONSOLE:
dhdpcie_readshared: address (0xfe0901f6) of pciedev_shared invalid
dhdpcie_init: dhd_bud_start() failed
dhdpcie_handle_dongle_trap: Dongle(wl2) trap detected. Restarting the system
C\FCDigital core power voltage set to 1.0V
SHMOO VER 1.13
S300001EF
000014A0
RDLYW0 00000004
RDENW0 00000037
RDQSW0
 04 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------
 08 --------++++++++++++++++++++++X++++++++++++++++++++++-----------
P\00\00\00W0
 09 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++
N\00\00\00W0
 01 -------+++++++++++++++++++++++++++X++++++++++++++++++++++++++---
 04 -+++++++++++++++++++++++++X+++++++++++++++++++++++++------------
 09 ----------------++++++++++++++++++++++++X+++++++++++++++++++++++
 12 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------
 14 ----------++++++++++++++++++++++++X++++++++++++++++++++++++-----
WRDQW0
 01 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-------+++-
 02 +++++++++++++++++++++++++X++++++++++++++++++++++++------+++++++-
 04 +++++++++++++++++++++++X++++++++++++++++++++++----------+++++++-
 05 +++++++++++++++++++++++++X+++++++++++++++++++++++++-----+++++++-
 11 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------
WRDMW0 00000024
WRDMW0 00000026
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Entry at 0x00008000
Closing network.
brd: module loaded
loop: module loaded
csw_retry 100
u32 classifier
    Actions configured
devtmpfs: mounted
NTP synchronized date/time: Sat Feb  7 01:52:56 2004
dhd_module_init in
ring_info_raw: 56
max H2D queues 134
  0000: 00 00 1a 8d 00 00 00 00
  0000: 00 60 37 8e 00 00 00 00
  0000: 00 94 46 8d 00 00 00 00
  0000: 00 40 17 8d 00 00 00 00
  0000: 00 80 1b 8d 00 00 00 00
  0000: 00 a0 1b 8d 00 00 00 00
  0000: 00 28 60 8d
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 75
CONSOLE: 000000.036 wl0: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)
CONSOLE: 000000.036 TCAM: 256 used: 135 exceed:0
CONSOLE: 000000.037 reclaim section 1: Returned 119324 bytes to the heap
CONSOLE:
ring_info_raw: 56
max H2D queues 134
  0000: 00 00 fc 8c 00 00 00 00
  0000: 00 80 fa 8c 00 00 00 00
  0000: 00 ac 46 8d 00 00 00 00
  0000: 00 c0 fb 8c 00 00 00 00
  0000: 00 a0 fa 8c 00 00 00 00
  0000: 00 c0 fa 8c 00 00 00 00
  0000: e0 45 ae 8f
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 74
CONSOLE:
SHMOO VER 1.13
S300001EB
000014C0
RDLYW0 00000004
RDENW0 00000037
RDQSW0
 10 ---------+++++++++++++++++++++++X++++++++++++++++++++++---------
 14 -----------+++++++++++++++++++++++X++++++++++++++++++++++-------
P\00\00\00W0
 01 ---++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----
 15 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--
N\00\00\00W0
 02 -----++++++++++++++++++++++++++X++++++++++++++++++++++++++------
 03 -----+++++++++++++++++++++++++X+++++++++++++++++++++++++--------
 08 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
 15 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-
WRDQW0
 02 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-
 08 ++++++++++++++++++++++++X+++++++++++++++++++++++----------+++++-
 09 -+++++++++++++++++++++++++X+++++++++++++++++++++++++------------
 12 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-
 13 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------
 15 --+++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
WRDMW0 00000024
WRDMW0 00000026
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Entry at 0x00008000
Closing network.
brd: module loaded
loop: module loaded
csw_retry 100
u32 classifier
    Actions configured
devtmpfs: mounted
NTP synchronized date/time: Sun Feb  1 20:43:36 2004
dhd_module_init in
ring_info_raw: 56
max H2D queues 134
  0000: 00 00 77 8d 00 00 00 00
  0000: 00 a0 be 8f 00 00 00 00
  0000: 00 14 a4 8e 00 00 00 00
  0000: 00 00 4f 8d 00 00 00 00
  0000: 00 c0 be 8f 00 00 00 00
  0000: 00 e0 be 8f 00 00 00 00
  0000: c0 b6 0c 8f
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 75
CONSOLE:
ring_info_raw: 56
max H2D queues 134
  0000: 00 40 38 8e 00 00 00 00
  0000: 00 58 45 8d 00 00 00 00
  0000: 00 40 fb 8c 00 00 00 00
  0000: 00 60 38 8e 00 00 00 00
  0000: 00 80 fc 8c 00 00 00 00
  0000: 40 88 43 8d
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 74
CONSOLE:
dhdpcie_readshared: address (0xfe1101ee) of pciedev_shared invalid
SHMOO VER 1.13
S300001EF
000014F0
RDLYW0 00000004
RDENW0 00000037
RDQSW0
P\00\00\00W0
N\00\00\00W0
 15 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++
WRDQW0
 00 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------+++++-
 03 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------+++++-
 04 ++++++++++++++++++++++X++++++++++++++++++++++-------------+++++-
 06 ++++++++++++++++++++++++X+++++++++++++++++++++++---------++++++-
 10 +++++++++++++++++++++++++X+++++++++++++++++++++++++-+-------+++-
WRDMW0 00000024
WRDMW0 00000026
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Startup canceled
CFE> ^C
CFE> ^C
CFE> ^C
CFE> ^C
CFE> ^C
CFE> ^C
CFE> tftpd
Start TFTP server
SHMOO VER 1.13
S300001EB
000014C0
RDLYW0 00000004
RDENW0 00000037
RDQSW0
 13 --------------+-++++++++++++++++++++++X+++++++++++++++++++++----
P\00\00\00W0
 00 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
N\00\00\00W0
 00 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
 06 ----++++++++++++++++++++++++X+++++++++++++++++++++++------------
 08 -------+++++++++++++++++++++++++X+++++++++++++++++++++++++------
 11 ---------------++++++++++++++++++++++++X+++++++++++++++++++++++-
 13 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-
WRDQW0
 10 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-
WRDMW0 00000024
WRDMW0 00000026
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Entry at 0x00008000
Closing network.
brd: module loaded
loop: module loaded
csw_retry 100
u32 classifier
    Actions configured
devtmpfs: mounted
NTP synchronized date/time: Mon Feb  2 18:20:40 2004
dhd_module_init in
dhd_attach(): thread:dhd_watchdog_thread:2987 started
PCIe shared addr read took 56383 usec before dongle is ready
ring_info_raw: 56
max H2D queues 134
  0000: 00 80 5b 8d 00 00 00 00
  0000: 00 80 10 8d 00 00 00 00
  0000: 00 74 11 8f 00 00 00 00
  0000: 00 40 10 8d 00 00 00 00
  0000: 00 a0 10 8d 00 00 00 00
  0000: 00 c0 10 8d 00 00 00 00
  0000: 00 44 a8 8f
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 75
dhd_attach(): thread:dhd_watchdog_thread:298a started
CONSOLE:
ring_info_raw: 56
max H2D queues 134
  0000: 00 00 fe 8c 00 00 00 00
  0000: 00 7c 11 8f 00 00 00 00
  0000: 00 c0 44 8d 00 00 00 00
  0000: 00 a0 fe 8c 00 00 00 00
  0000: 80 41 a8 8f
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 74
dhd_attach(): thread:dhd_watchdog_thread:298d started
CONSOLE:
dhdpcie_readshared: address (0xfe0b01f4) of pciedev_shared invalid
C\F8Digital core power voltage set to 1.0V
SHMOO VER 1.13
S300001EB
00001500
RDLYW0 00000004
RDENW0 00000038
RDQSW0
P\00\00\00W0
 07 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--
 11 ---++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-
N\00\00\00W0
 03 ----+++++++++++++++++++++++++X+++++++++++++++++++++++++---------
 05 ------++++++++++++++++++++++++++X++++++++++++++++++++++++++-----
WRDQW0
 04 ++++++++++++++++++++++X++++++++++++++++++++++------------++++++-
 05 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-
 14 +++++++++++++++++++++++++X+++++++++++++++++++++++++--------++++-
WRDMW0 00000024
WRDMW0 00000026
ADDR
 00 +++++++++++++++++++++S+++++++++X++++++++++++++++++++++++++++++++
Init Arena
Init Devs.
DDR Clock: 800 MHz
Entry at 0x00008000
Closing network.
brd: module loaded
loop: module loaded
csw_retry 100
u32 classifier
    Actions configured
802.1Q VLAN Support v1.8 Ben Greear <[email protected]com>
devtmpfs: mounted
NTP synchronized date/time: Sat Feb  7 07:34:16 2004
dhd_module_init in
ring_info_raw: 56
max H2D queues 134
  0000: 00 80 1a 8d 00 00 00 00
  0000: 00 d0 46 8d 00 00 00 00
  0000: 00 c0 67 8d 00 00 00 00
  0000: 00 80 77 8d 00 00 00 00
  0000: 00 a0 77 8d 00 00 00 00
  0000: a0 0b 45 8d
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 75
CONSOLE:
ring_info_raw: 56
max H2D queues 134
  0000: 00 e8 46 8d 00 00 00 00
  0000: 00 80 75 8d 00 00 00 00
  0000: 20 2d 7c 8d
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 74
CONSOLE:
SHMOO VER 1.13
S300001EB
000014C0
RDLYW0 00000004
RDENW0 00000038
RDQSW0
 13 ----------------++++++++++++++++++++++X+++++++++++++++++++++----
P\00\00\00W0
N\00\00\00W0
 00 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
WRDQW0
 10 +++++++++++++++++++++++++X+++++++++++++++++++++++++--------++++-
WRDMW0 00000024
WRDMW0 00000026
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Init Arena
Init Devs.
DDR Clock: 800 MHz
Entry at 0x00008000
Closing network.
brd: module loaded
loop: module loaded
csw_retry 100
u32 classifier
    Actions configured
devtmpfs: mounted
NTP synchronized date/time: Sun Feb  8 01:46:32 2004
dhd_module_init in
ring_info_raw: 56
max H2D queues 134
  0000: 00 00 7d 8d 00 00 00 00
  0000: 00 e0 a4 8e 00 00 00 00
  0000: 00 58 43 8d 00 00 00 00
  0000: 00 c0 4b 8d 00 00 00 00
  0000: 00 80 7e 8d 00 00 00 00
  0000: 00 a0 7e 8d 00 00 00 00
  0000: 00 78 78 8d
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 75
CONSOLE:
ring_info_raw: 56
max H2D queues 134
  0000: 00 e0 7e 8d 00 00 00 00
  0000: 00 18 b6 8f 00 00 00 00
  0000: 00 00 71 8d 00 00 00 00
  0000: 00 00 fd 8c 00 00 00 00
  0000: 00 20 fd 8c 00 00 00 00
  0000: 00 11 40 8d
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 74
CONSOLE:
Thanks again for reading!
aiziks251
aiziks251's picture
Just realized I posted the
Just realized I posted the entire log...
Sorry.  I know double-posts re usually frowned on, but I didn't see any way to edit my post.
This is the most recent boot only.  Don't read the previous post unless you want to go through the wild journey I went through.
SHMOO VER 1.13
S300001EB
000014C0
RDLYW0 00000004
RDENW0 00000038
RDQSW0
P\00\00\00W0
N\00\00\00W0
WRDQW0
WRDMW0 00000024
WRDMW0 00000026
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Init Arena
Init Devs.
DDR Clock: 800 MHz
Entry at 0x00008000
Closing network.
brd: module loaded
loop: module loaded
csw_retry 100
u32 classifier
    Actions configured
devtmpfs: mounted
dhd_module_init in
ring_info_raw: 56
max H2D queues 134
  0000: 00 78 78 8d
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 75
CONSOLE:
ring_info_raw: 56
max H2D queues 134
  0000: 00 11 40 8d
  0000: 08 00 00 00
mac: 6
10 da 43 87 39 74
CONSOLE:
Kong
Kong's picture
Stop it at the CFE prompt
Stop it at the CFE prompt through serial, e.g.:
Startup canceled
CFE> ^C
CFE>
and run command:
nvram erase
turn it off, turn it on and most likely it works again.
aiziks251
aiziks251's picture
Holy Crap.
Holy Crap.
Thank you so much.  I can't believe it was that easy.
I thought for sure I had a brick on my hands.
--Isaac
