see adsl modem from R7000 lan side
3 posts / 0 new
replabrobin
replabrobin's picture
When using the r7000 I have a vigor 120 adsl modem for internet access. I used to have a tplink adsl modem running in bridge mode with a wnr3500l toastman tomato as router.
The vigor adsl modem is running in bridge mode (by default I think); it does have a web interface on 192.168.2.1.
With tomato I can get access to the 192.168.1.0/24 network using these scripts
script_fire="iptables -I POSTROUTING -t nat -o \$(nvram get wan_ifname) -d 192.168.2.0/24 -j MASQUERADE"
script_wanup="ip addr add 192.168.2.2/24 dev \$(nvram get wan_ifname) brd +"
Is there any way to do this using genie and static routes or something?
Nicholas Thompson
Nicholas Thompson's picture
Did you find out how to do
Did you find out how to do this? I have the same problem. I cannot see the web interface on 192.168.2.1 and nothing appears on 192.168.2.x when I use LanScan.
replabrobin
Unfortunately I don't think
Unfortunately I don't think this is possible in stock firmware.
