Hi all,
There are some difference between the 614L router being sold in US and Europe. They Europian version comes with different version of bootloader. This verions of boot loader does not load non-lzma raw kernel
format trx images although this kind of imgaes can be flashed.
The Tomato firmware for the Europian edition has been uploaded in this site by Nachi. Please download and use this firmware from http://www.myopenrouter.com/download/10413/tomato_wgr614l-lzma.
Souvik
since I was the first coming up with this problem - thank you for your help and support.
Is there any possibility to do the same with a DD-WRT image? I learned that tomato lacks WPA support which is essential for me.
Thanks guys, keep up the good work.
Hi again,
some issues:
- SSH does not work (openpty could not execute)
- no PPPoE connection (connection establishes but no internet)
- no WPA support
See a bootlog here, perhaps it can help someone:
http://nopaste.ch/46d6b5bd74bdea9.html
Thnks Lightning. We will look into those issues...
It seems i had the same problem with my wgr614l bought in France. It's the only tomato firmware version i can use. Does someone have a similar solution with dd-wrt? I'm ready for all your tests if you don't have a european version.
Thanks for your help.
Please check the link below
http://www.myopenrouter.com/forum/thread/10396/Blinking-power-LED-after-...
