This has been documented/discussed elsewhere, I've come to find, but Tomato doesn't handle the 2.4G band on the R6250.
Range, signal, and connectivity are fine with OEM firmware and with DD-WRT, but with Tomato, range drops to about 10 feet, unobstructed, and with poor speed/throughput.
It seems clear that there's simply a code problem, since the hardware is healthy and 2.4G does technically work with Tomato...just not correctly.
The 5G band works fine.
