After about a year of running DD-WRT on my WNR3500Lv1 with zero issues, I decided to try Tomato (tomato-K26USB-1.28.7500.2MIPSR2Toastman-RT-Ext).
I've got into the admin interface via wireless, but the connection always drops every few seconds. Also, when I physicsally connect to it via LAN, the Network is stuck on 'Identifying'
As it is, it's completely useless because I can't connect to it except for Wireless, but that drops every few seconds.
Help would be much appreciated.
Is ssh or telnet enabled by default on that build? If so, can you get in that way?
Also, have you tried the 30/30/30 reset?
Change topic to "Downgraded to Tomato ... problems!" and then install Kong Mod DD-WRT, that zero problem thing.
Really? Tomato - Shibby's version - is real sweet on my WNR3500Lv2. Then I've got a BrainSlayer DD-WRT on my cheap Rosewill that I'm using as a repeater. As much as I appreciate that that's working pretty well, I strongly prefer the Tomato UI.
lol, you made my holidays, thanks for that, cheers!
