WGR614L with DD-WRT and remote management
2 posts / 0 new
fusk
I basically just have one question, because the only reason why i wanna change the firmware, is to increase the transmit power, read that dd-wrt adjusts it from 28mw to 70mw.
now, i'm not psysical near the router, so i'm doing remote management, but when i update the firmware, will dd-wrt have remote management enable by default, so i can reconnect to it, or do you have to be connected to it's wireless signal?
and as far as i know, you connect to dd-wrt like you normally would do.
192.168.1.1
user: root
password: admin
thanks in advance
achilles
Whenever u do a f/w upgrade
Whenever u do a f/w upgrade you need to reconnect to the router either through its LAN ports using wired connection or through a wireless connection ....
