What's the right place to download the right dd-wrt for the R7000?
4 posts / 0 new
joe1212
joe1212's picture
I have an r7000 and it's been great and all the articles pick it as a recommended router for dd-wrt. I've had dd-wrt on it for a couple of years now, and wanted to upgrade.
I couldn't find any clear ideas of which FW to use. I found this link:
which has a file dd-wrt.K3_r7000.chk from Feb 2018. That's good but the existing dd-wrt installation seems to want a .bin file.
I logged in by ssh and tried to use ddup with the path to the .chk file and that didn't work.
I then did ddup --flash-latest
That did work, and it did it by downloading from:
http://www.desipro.de/ddwrt/K3-AC-Arm/TEST/
which I assume is the nightly build directory.
Everything worked, but do I want to be running nightly builds on this? Is there some more suitable download location for a stable build?
JeffreyHollister
JeffreyHollister's picture
How does the various products
How does the various products mentioned on the list compare, and which one can be said to be the best? https://smartelectricscooters.com/best-scooter-helmet/
djk44883
djk44883's picture
You can go to either read
You can go to either read  http://www.desipro.de/ddwrt/K3-AC-Arm/Supported Models
Build dd-wrt.v24-K3_AC_ARM_STD.bin supports:
(at the bottom of the list)
NETGEAR R7000
the_prof
the_prof's picture
I don't see a file for the
I don't see a file for the r7000 only the R7000P which is different..
