Where do I begin to learn how to flash my R7000? - Super Noob
4 posts / 0 new
jerry8989
I'm so happy I found this forum.  I've been looking to use a VPN service, but most of the ones I have looked at don't support my Netgear R7000.  They said I can update the firmware where it will work with their services but if I mess up it will no longer work.  What is the recommend best place to start to update my router?
Does anyone have a preference on a VPN service?  I apologize if I'm not supposed to ask about this in this post.
Thank you so much for any help you can give me.
jerry8989
mesteele101
jerry8989
mesteele,  Thank you fo the
mesteele,  Thank you fo the link.  Should I though this first or should I find a VPN service first?  Or will all require I use this firmware?
Thank you again
