Hi there,
Anyone can point me where I can get ddwrt-to-netgear-fw-R7800.bin file? I got 403 forbidden while accessing http://www.desipro.de/ddwrt/K3-AC-IPQ806X/
Thanks in advance!
Hi there,
Thanks in advance!
Here ya go, direct link to your required firmware http://www.desipro.de/ddwrt/K3-AC-IPQ806X/NetgearFW/ddwrt-to-netgear-fw-R7800.bin
Hello! tell me where to get the firmware ddwrt-to-netgear-fw-R7800.bin ? According to the links got 403 forbidden while accessing http://www.desipro.de/ddwrt/K3-AC-IPQ806X/.......If not hard reset on the mailbox [email protected] thanks in advance!!
Здравствуйте! скажите мне , где взять прошивку DDWRT к NetGear-Fw-R7800.bin? По ссылкам получили 403 запрещено при доступе к HTTP: //www.desipro.de/ddwrt/K3-AC-IPQ806X / ....... Если не трудно сбросить на почтовый ящик [email protected] заранее спасибо! !
Where can I find ddwrt-to-netgear-fw-R7800.bin the web page is not working
Thanks in advance
https://mega.nz/#!M0pzFYrT!aDHQMr0PhhXpz3kQKKzVVPvWHATQ-it1ew3Y4cYMnhg
I have just spend some hours trying to locate the lost `ddwrt-to-netgear-fw-R7800.bin` file. To save other people the trouble:
https://www.dropbox.com/s/e2bqagpgkcm7pul/ddwrt-to-netgear-fw-R7800.bin?...
will be there for a few months or years …
Thank you, jandockx.
