WNDR4500 LED
12 posts / 0 new
Tathagata Das
Tathagata Das's picture
WNDR4500 LED
I released a firmware for WNDR4500 couple of days before. I mentioned that LEDs are not supported. Actually LEDs on WNDR4500 (with DD-WRT) do not show the right Netgear standard colors. For example, the wireless status LED glows green while the default behavior is blue. However LEDs are on.
shibby
shibby's picture
2,4GHz led is green, 5GHz is
2,4GHz led is green, 5GHz is blue
Buttons:
gpio 6 - reset
gpio 4 - WPS
gpio 5 - wireless
Leds:
gpio disable 1 - WPS led on
gpio disable 2 - power led on green
gpio disable 3 - power led on orange
gpio disable 6 - activated USB ports
gpio disable 8 - USB 1 led on
gpio disable 9 - 2,4GHz led on
gpio disable 11 - 5GHz blue led on
MikeKTex
MikeKTex's picture
I need VPN support, do you
I need VPN support, do you have a version of this that had VPN built in?
Subhra
Subhra's picture
Yes VPN server (PPTP) is
Yes VPN server (PPTP) is included in this build. Please consult the description for the list of major features included in this build.
MikeKTex
MikeKTex's picture
thank you very much, I guess
thank you very much, I guess I stopped reading at passthrough and thought that was all it had
Subhra
Subhra's picture
Have any one identified gpio
Have any one identified gpio pin corresponding to WAN LED ??
@shibby would you like to provide some gpio information about the WAN LED ??
SteveO
SteveO's picture
I have the Costco version of
I have the Costco version of WMDR4500 - RA4500.
Will this firmmware work on the RA4500?
Subhra
Subhra's picture
As far I read from netgear
As far I read from netgear forums, I learnt that WNDR4500 and RA4500 are functionally same but accept different type of firmwares. Even the stock firmware of WNDR4500 is not accepted by the RA4500.
I don't have a RA4500. But I can predict that this dd-wrt firmware for WNDR4500 wouldn't be accepted by RA4500.
SteveO
SteveO's picture
Thanks. I've decided to
Thanks. I've decided to purchase the WNDR4500 and return the RA4500 to Costco. Apparently they also have different a different board and chips.
Costco usually does better than this, but I guess they can't get it right every time.
Subhra
Subhra's picture
dd-wrt firmware for WNDR4500 is build solely for WNDR4500 hardware, using this for any other hardware may damage the same.
Bob Snelgrove
Bob Snelgrove's picture
Anyone know how to convert
Anyone know how to convert the Costco version th the WNDR4500?
bob
afeng11
afeng11's picture
anyone konw how to modify
anyone konw how to modify source code to turn on WAN an LAN leds in tomato?thank you!
