R6300v1 has anyone tried Tomato Shibby 140-MultiWan AIO?
6 posts / 0 new
nomendos
nomendos's picture
I'd just appreciate if someone can confirm if Tomato Shibby 140-MultiWan AIO works fine on R6300v1 without bricking it (upgrading from the previous versions 124 or 132 currently running on it)?
Note: I looked history of reported installs at https://anon.groov.pl/index.php?model=Netgear+R6300v1 but the latest it lists is "20150107 K26AC USB" which I can not tell which from https://tomato.groov.pl/download/K26RT-AC/ of the 124,132 or 140-multiwan it is as they have different dates that I can not identify to the above versions nor is it even Shibby's version?
mrdon213
mrdon213's picture
Shibby is no longer supported
Shibby is no longer supported or updated. You should look at freshtomato, it was forked from shibby and is being kept up to date.
nomendos
nomendos's picture
Has anyone tried FreshTomato
Has anyone tried FreshTomato 2020.8 on R6300 v1?
From: https://freshtomato.org/downloads/freshtomato-mips/2020/2020.8/K26RT-AC/freshtomato-Netgear-R6300V1_RT-AC6x-2020.8-AIO-64K.zip
Or if from elsewhere to provide from where.
nomendos
nomendos's picture
I see quite a number of
I see quite a number of Shibby 140 as well as FreshTomato 2020.8 at
https://anon.groov.pl/index.php?model=Netgear%20R6300%20V1
Now I just need to "tripple-check" if I can just flash from Shibby web-UI to FreshTomato or there might be any other way recomended to avoid bricking. Advice appreciated?
nomendos
nomendos's picture
Ping,
Ping,
Anyone can confirm if FreshTomato 2020.8 can be flashed from Shibby 128 web UI? (following clear NVRAm and reset to factory defaults 1st)
mrdon213
mrdon213's picture
Yes it can be flashed
Yes it can be flashed directly from shibby! Just make sure to esase NVRAM when you do, there have been a lot of changes in NVRAM.
