R6300V2 dd wrt LAN IP disappeared
5 posts / 0 new
ice9
While configuring my R6300V2, I encountered a situation where the IP address of the router is "missing".  A scan of 192.168.0.xxx and 192.168.1.xxx does not yield anything.  I did change the static LAN IP from 192.168.1.1 to 192.168.1.8, and successfully rebooted after that.  But a couple of reboots neither shows up on a scan.
Any ideas?  Does a hard reset affect the IP?  Is it possible to get in through the radios?
ice9
So I was able to get the
So I was able to get the router back with a 10 second reset.  But I don't know why it is locking up when I change some parameters.
Any general guidance would be appreciated.  I have used this router model for 7 years without problems like this, so I am somewhat at a loss.
devadmin
I have seen this sort of
I have seen this sort of issue when the power supply is starting to go bad.
If you have another you can test with you might try that.
ice9
Interesting.  I have many
Interesting.  I have many power supplies, I will try another tonight.  Thanks.
devadmin
Cool,
Cool,
Let us know how it works out.
