r6400v1 bad flash using wrong back-to-ofw version
2 posts / 0 new
alexdgreen
alexdgreen's picture
Hi All,
After a weekend of bricking, un-bricking and re-unbricking I think i've just shot myself royally in the foot...
Basically, I wanted to get to stock so used the back-to-ofw images available, except that stupidly, instead of selecting the r6400-to-ofw .trx file, i chose the R7000-to-ofw and it should got on with it, rebooted and then magically it came up with the R7000 firmware.. only then did i realise my error.
I was able to flash back to a lower version of the actual r6400 but now the router is behaving weirdly, it would re-flash and any chk i select in the stock UI reports "
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.
I can't get the TFTP method to work and all MAC addresses in the UI now report as 00:FF:FF:FF:FF:FF for all interfaces..
Does anyone have a fixed image that has the model check removed as I suspect that may one method to override the checks stopping the flash..
Or have I lost my router forever and can bin it?
TIA
A
alexdgreen
just us chickens?
just us chickens?
