Bricked after attempting to upgrade firmware
2 posts / 0 new
kbezold
I had FreshTomato "2020.1 K26ARM USB AIO-64K" installed and working well on my Netgear R7000 AC1900 until I updated my computer's OS from Linux Mint to 20.3 which in turn updated samba to 4.13.17 which no longer supports SMB1, so cifs would no longer mount from the router.
I tried flashing "freshtomato-R7000-ARM_NG-2022.1-AIO-64K.trx", but received a "Bad trx header".
I then tried flashing "R7000-back-to-ofw.trx" and it said it was successful.
But now the router will not boot.  (Solid amber light.  Never blinks.)
I've removed the cover and connected a serial/USB adapter and ran "minicomp -s" to see what was going on.  Here is the output from the attempted boot:
$ minicom -s
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyUSB0, 22:14:26
Press CTRL-A Z for help on special keys
Digital core power voltage set to 1.0V
Decompressing...done
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S300001D3
00001330
RDLYW0 00000004
RDENW0 00000032
RDQSW0
    0000000000111111111122222222223333333333444444444455555555556666
    0123456789012345678901234567890123456789012345678901234567890123
00 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------
01 --------++++++++++++++++++++++++++X++++++++++++++++++++++++++---
02 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------
03 ----+++++++++++++++++++++++++X+++++++++++++++++++++++++---------
04 --+++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
05 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------
06 -+++++++++++++++++++++++++X++++++++++++++++++++++++-------------
07 --------++++++++++++++++++++++++++X++++++++++++++++++++++++++---
08 -------++++++++++++++++++++++++X+++++++++++++++++++++++---------
09 -------------+++++++++++++++++++++++++X++++++++++++++++++++++++-
10 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
11 ----------------++++++++++++++++++++++X++++++++++++++++++++++---
12 -------+++++++++++++++++++++++++X+++++++++++++++++++++++++------
13 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--
14 --------+++++++++++++++++++++++++X+++++++++++++++++++++++++-----
15 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++
PW0
00 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------
03 -----+++++++++++++++++++++++++X++++++++++++++++++++++++---------
04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------
05 -----+++++++++++++++++++++++++X+++++++++++++++++++++++++--------
07 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++--
09 ------------++++++++++++++++++++++++++X++++++++++++++++++++++++-
11 ----------------++++++++++++++++++++++++X++++++++++++++++++++++-
12 -------++++++++++++++++++++++++++X+++++++++++++++++++++++++-----
13 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--
14 --------++++++++++++++++++++++++++X+++++++++++++++++++++++++----
NW0
00 ----+++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----
01 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-
02 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++------
03 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------
04 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------
05 ---++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----
06 -+++++++++++++++++++++++++X+++++++++++++++++++++++++------------
07 -------++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-
08 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
09 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
10 -------++++++++++++++++++++++++++X+++++++++++++++++++++++++-----
11 -------------++++++++++++++++++++++++X+++++++++++++++++++++++---
12 -----++++++++++++++++++++++++++X++++++++++++++++++++++++++------
13 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++--
14 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----
15 -----------++++++++++++++++++++++++++X++++++++++++++++++++++++++
WRDQW0
00 ++++++++++++++++++++++++X+++++++++++++++++++++++------+++++++++-
01 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-
02 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
03 +++++++++++++++++++++++++X++++++++++++++++++++++++-----++++++++-
04 ++++++++++++++++++++++X++++++++++++++++++++++----------++++++++-
05 ++++++++++++++++++++++++X++++++++++++++++++++++++-----+++++++++-
06 +++++++++++++++++++++++X++++++++++++++++++++++----------+++++++-
07 +++++++++++++++++++++++++X++++++++++++++++++++++++------+++++++-
08 +++++++++++++++++++++++X+++++++++++++++++++++++--------++++++++-
09 -++++++++++++++++++++++++X++++++++++++++++++++++++----------+++-
10 +++++++++++++++++++++++++X++++++++++++++++++++++++------+++++++-
11 ---++++++++++++++++++++++++X+++++++++++++++++++++++-----------+-
12 ++++++++++++++++++++++++X++++++++++++++++++++++++------++++++++-
13 --++++++++++++++++++++++++X++++++++++++++++++++++++----------++-
14 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-
15 -++++++++++++++++++++++++X+++++++++++++++++++++++----------++++-
WRDMW0 00000024
WRDMW0 00000025
ADDR
00 +++++++++++++++++++S+++++++++++X++++++++++++++++++++++++++++++++
CFE for Foxconn Router R7000 version: v1.0.27
Build Date: Thu Jun 28 11:42:11 CST 2018
Init Arena
Init Devs.
Boot up from NAND flash...
Bootcode Boot partition size = 524288(0x80000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.15.1 (r407936)
et1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.15.1 (r407936)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytes
Device eth0:  hwaddr 14-59-C0-A6-8F-67, ipaddr 192.168.1.1, mask 255.255.255.0
Checking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)
Loading: ..... 4778464 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
console [ttyS0] enabled, bootconsole disabled
brd: module loaded
loop: module loaded
No NAND flash type found
nflash: found no supported devices
PPPoL2TP kernel driver, V0.17
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
early_nvram_get: Failed reading nvram var gpio0
early_nvram_get: Failed reading nvram var gpio1
early_nvram_get: Failed reading nvram var gpio2
early_nvram_get: Failed reading nvram var gpio3
early_nvram_get: Failed reading nvram var gpio4
early_nvram_get: Failed reading nvram var gpio5
early_nvram_get: Failed reading nvram var gpio6
early_nvram_get: Failed reading nvram var gpio7
early_nvram_get: Failed reading nvram var gpio8
early_nvram_get: Failed reading nvram var gpio9
early_nvram_get: Failed reading nvram var gpio10
early_nvram_get: Failed reading nvram var gpio11
early_nvram_get: Failed reading nvram var gpio12
early_nvram_get: Failed reading nvram var gpio13
early_nvram_get: Failed reading nvram var gpio14
early_nvram_get: Failed reading nvram var gpio15
early_nvram_get: Failed reading nvram var gpio16
early_nvram_get: Failed reading nvram var gpio17
early_nvram_get: Failed reading nvram var gpio18
early_nvram_get: Failed reading nvram var gpio19
early_nvram_get: Failed reading nvram var gpio20
early_nvram_get: Failed reading nvram var gpio21
early_nvram_get: Failed reading nvram var gpio22
early_nvram_get: Failed reading nvram var gpio23
early_nvram_get: Failed reading nvram var gpio24
early_nvram_get: Failed reading nvram var gpio25
early_nvram_get: Failed reading nvram var gpio26
early_nvram_get: Failed reading nvram var gpio27
early_nvram_get: Failed reading nvram var gpio28
early_nvram_get: Failed reading nvram var gpio29
early_nvram_get: Failed reading nvram var gpio30
early_nvram_get: Failed reading nvram var gpio31
ehci_hcd 0000:00:0b.1: EHCI Host Controller
ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci_hcd 0000:00:0b.0: OHCI Host Controller
ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
xhci_hcd 0000:00:0c.0: xHCI Host Controller
xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3
xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000
xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
usb usb3: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
xHCI xhci_add_endpoint called for root hub
xHCI xhci_check_bandwidth called for root hub
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
u32 classifier
    Actions configured
TCP cubic registered
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
sit0: Disabled Privacy Extensions
ip6tnl0: Disabled Privacy Extensions
early_nvram_get: Failed reading nvram var qos_enable
early_nvram_get: Failed reading nvram var wla_repeater
brcmnand: found no supported devices
VFS: Cannot open root device "mtdblock3" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[<c00451f8>] (unwind_backtrace+0x0/0xe4) from [<c0359dac>] (panic+0x68/0x188)
[<c0359dac>] (panic+0x68/0x188) from [<c0009214>] (mount_block_root+0x238/0x288)
[<c0009214>] (mount_block_root+0x238/0x288) from [<c0009510>] (prepare_namespace+0x160/0x1c0)
[<c0009510>] (prepare_namespace+0x160/0x1c0) from [<c0008e88>] (kernel_init+0x1c8/0x218)
[<c0008e88>] (kernel_init+0x1c8/0x218) from [<c003fb58>] (kernel_thread_exit+0x0/0x8)
CPU0: stopping
[<c00451f8>] (unwind_backtrace+0x0/0xe4) from [<c003e2f0>] (do_IPI+0xfc/0x180)
[<c003e2f0>] (do_IPI+0xfc/0x180) from [<c0430f88>] (__irq_svc+0x48/0xe8)
Exception stack(0xc046ff78 to 0xc046ffc0)
ff60:                                                       c047e764 00000000
ff80: c046ffc0 00000000 c046e000 c047abc8 c04970a8 c047abc0 00025ba0 413fc090
ffa0: 0000001f 00000000 c04cacb8 c046ffc0 c003fbb0 c003fbb4 60000013 ffffffff
[<c0430f88>] (__irq_svc+0x48/0xe8) from [<c003fbb4>] (default_idle+0x24/0x28)
[<c003fbb4>] (default_idle+0x24/0x28) from [<c003fd1c>] (cpu_idle+0x40/0x94)
[<c003fd1c>] (cpu_idle+0x40/0x94) from [<c0008c64>] (start_kernel+0x320/0x37c)
[<c0008c64>] (start_kernel+0x320/0x37c) from [<00008084>] (0x8084)
<Ctrl-C> does nothing and I can't get to a CFE prompt to even attempt flashing through tftp.
Any ideas on how to proceed?  Or is this router a complete brick?
kbezold
nmrpflash was able to unbrick
nmrpflash was able to unbrick my router!
