How to get r7000 working with sky broadband
2 posts / 0 new
Jsfinchy1986
Hi
sorry I am useless but want to learn!!
i want to replace my sky broadband modem/router ER115 with my Netgear nighthawk R7000.
i got my username and password using Wireshark. But when it comes to the interenet test it doesn’t connect just has orange light.
at the minute I have switched off the wireless on ER115 and using the R7000 as a wireless access point.
if someone could talk me through step by step that would be great as I am pulling my hair out.
thanks
pb1983
Is your R7000 WAN port
Is your R7000 WAN port connected to a LAN port on the ER115? Do you want to turn off routing on the ER115 and use as a bridge to the R7000?
