Need your advice on using the R7000 as firewall / 1:1 NAT
3 posts / 0 new
erann
Hi Guys ,
Hope I'm not breaking any rules asking this question.
I have a router from my ISP which is configured as DHCP (its also have landline phone output) and I must keep using that router.
The ISP block the firewall access in the router so I was recommaneded to put a router with firewall before the ISP's router (I'm using fiber optic connection so I have lan adapter before the router).
currently I have R7000 which was flushed with DD-WRT long time ago with DD-WRT v3.0-r37015M kongac (09/23/18)
Would you recommand me keep using this firmware or flush to something else if all I need is firewall and 1:1 NAT ?
Thank you guys !!!
Awsome forum :-)
e38BimmerFN
Either run the R7800 in
Either run the R7800 in router mode with a firewall and put the R7800 IP address it gets from the FW into it's DMZ or use the R7800 in AP mode.
e38BimmerFN
Either run the R7000 in
Either run the R7000 in router mode with a firewall and put the R7000 IP address it gets from the FW into it's DMZ or use the R7000 in AP mode.
