network bandwidth usage
2 posts / 0 new
mitcheal
My wife is asking me what is using all the bandwidth on the network.  i have an R7000 with netgear firmware.  is there a way i can tell?  if not, can i install a thrid party firmware that will show me and still work with disney (from within the router, not the device)
thanks,
mitch.
Aleks
Hi Mitcheal, you can try this
Hi Mitcheal, you can try this. It will show you devices conected on your router and the bandwith use by devices: https://github.com/vortex-5/ddwrt-bwmon
