hello!
I can not download the file ddwrt-netgear-r7800.bin for flash from https://www.myopenrouter.com/download/dd-wrt-kong-mod-netgear-r7800-2018....
There are only the link form netgear to dd-wrt.
all other links are go to amazon...
thanks for help
Have you tried directly on the dd-wrt web site?
Can I flash the .bin file form dd-wrt website over a existing kong-mod firmware?
Or must I flash back to original firmware and flash then the bin from dd-wrt website?
thanks for help
I believe you can. However to be safe and ensure the WRT gets applied well and correctly and ensure it works well, I would flash back to OEM FW, factory reset once more after OEM is back on. Then go in and sent the WRT FW.
I have also downloaded this file but when I tried to open it, it turned up with some error messages along with some error. This error leads to the deletion of some of my data from the laptop for which I had to contact Data Recovery Dubai for the help. And they really helped me with the solutions to get back the lost data.
