I am trying to use iptable to change outbound WAN TTL to 65 and can't get it to work. Here is the command I am placing in the firewall.
iptables -t mangle -A POSTROUTING -o eth0 -j TTL --ttl-set 65
I've tried other ports as well, doesn't seem to change anything.
Problem solved, I removed the -o -eth0
iptables -t mangle -A POSTROUTING -j TTL --ttl-set 65
