QoS settings won't stick (Voxel), effectively no QoS available.
3 posts / 0 new
spxak1
spxak1's picture
I have been using Voxel's excellent firmware and I am grateful for this.
The only problem I have (and I had the same issue with the stock firmware, regardless of version) is with QoS.
The main issue is that when I choose a priority for a connected device, set it and save, when I click again, it is set back to what it was (usually to low). As such I cannot change the priority which renders the whole point of QoS null.
Additionally, since after I installed Voxel's firmware, the router cannot do a speed test anymore. I click to start, and everything is greyd out.
Any help (mainly for the former issue) would be great. The problem is so large that when my server (whom I want at lowest priority) downloads files (cloud backups/restores) my Smart TV (which I want at highests) pauses playback from BBC iPlayer and only resumes if I stop the server. This should not be happening.
Thank you.
e38BimmerFN
e38BimmerFN's picture
You might post about this
morroterri
morroterri's picture
In my opinion, you should
In my opinion, you should check carefully one more time you will find out where the problem you are having.
GoMovies
